75 electrical problem ?
Old Sep 11, 2010 | 04:37 PM
Big Fish 10's Avatar
Big Fish 10
Cruising
Default 75 electrical problem ?
75 with auto trans. starts no problem but when I go to put it in drive starter starts trying to engage. does not do it in neutral or reverse. Also with key in on position not running moved gear shift to drive and it tried to start. Would this be a bad neutral safety switch ? Any help please.
Old Sep 11, 2010 | 04:47 PM
speedreed8's Avatar
speedreed8
thats where i would start looking, sounds like it is shorting internally. and getting power from somewhere to the solenoid.
Old Sep 11, 2010 | 05:02 PM
...Roger...'s Avatar
...Roger...
Unplug the seat belt bypass relay under the hood on passenger side and see if that stops it.
Old Sep 11, 2010 | 05:40 PM
Big Fish 10
Cruising
Default Seat belt
Thanks Roger tried that did not help
Old Sep 11, 2010 | 07:10 PM
thiatt's Avatar
thiatt
I would check the shifter linkage under the car to see if the silinoid wire is shorted when the shifter is in D. neutral saftey just opens the circuit not engage the silinoid.
Old Sep 11, 2010 | 07:17 PM
Big Fish 10
Cruising
Thanks thiatt I will try that in the morning.
Old Sep 11, 2010 | 08:53 PM
...Roger...
Also try disconnecting the seat belt interlock relay in the console after the car is started.
Old Sep 12, 2010 | 08:48 AM
Big Fish 10
Cruising
Ok now that ive slept had coffee went back to basics. Started car unpluged neutral safety switch put into gear no more grinding. Will order switch today. Thanks for everybodys replys.
To 75 electrical problem ?
