sidepipe fumes
Old Sep 12, 2010 | 09:27 AM
79c3man's Avatar
79c3man
Default sidepipe fumes
I have a 79 vette with sidepipes and the exhaust fumes are entering the car when driving and when I sit at stop lights ,the carb is running rich (edelbrock 750) swapped over to a holley 600 ,any suggestions ,
Old Sep 12, 2010 | 10:05 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Suggestions? Take your pick and choose 1.
a. close the windows
b. don't sit at stop lights
c. wear a mask
d. rebuild carb
e. replace exhaust
f. watch out for the environmentalists
Old Sep 12, 2010 | 10:56 AM
Dantana's Avatar
Dantana
enjoy the buzz
Old Sep 12, 2010 | 01:23 PM
7T1vette's Avatar
7T1vette
Fix the 'rich' carb mixture problem and drive into the wind.
Old Sep 12, 2010 | 04:40 PM
79c3man's Avatar
79c3man
let me rephrase the question ,does anyone have a c3 with sidepipes and have a exhaust problem smell in car , is this what to expect ,I'm trying to narrow down the problem
Old Sep 12, 2010 | 07:36 PM
baxsom's Avatar
baxsom
You need to tune your carb, if it is new a rebuild is not neccessarily needed. Sounds like the idle mixture screws are out too far or the power valve is blown.
Old Sep 12, 2010 | 08:30 PM
fugawi's Avatar
fugawi
i have factory style sidepipes, and i come home smelling like gas..thats the way ,uh hu ,uh hu, i like it... yes its in tune..
Old Sep 12, 2010 | 08:35 PM
TimAT's Avatar
TimAT
Narrow this down- is it a raw gas smell or a rich exhaust smell? Smell like a gas pump or make your eyes burn?
Ol' Red has worn sidepipes since it was built (Nov 68, came from the factory, and got switch to header/sidepipes in '71). The only real problem is when the power valve in the carb let go- it'd make your eyes burn.
Old Sep 12, 2010 | 08:45 PM
John A F's Avatar
John A F
I have Hooker sidepipes on my 79. No objectionable odors come into the cabin when driving or at a stop sign, even when the T tops are off. They affect my ears more than my nose.
Old Sep 12, 2010 | 09:21 PM
baja216's Avatar
baja216
Old Sep 12, 2010 | 09:30 PM
Duke94's Avatar
Duke94
I have a 78' with side pipes. Never had a problem with fumes. Are yours the Hooker side pipes?
Gary
Old Sep 12, 2010 | 09:35 PM
jordan89's Avatar
jordan89
Old Sep 13, 2010 | 07:35 PM
MyRed69's Avatar
MyRed69
Rebuilding the carb will not affect whether exhaust will get into the cabin or not; two separate issues. Exhaust would be getting in even if you had F/I. I am switching to side exhaust on my 69 and will prob be running with the tops off and the back window out most of the time and was wondering the same thing about fumes. Before i pulled the body i used to come home smelling like exhaust and the old lady hated it.
To the O/P, check for openings in the firewall, the rubber plugs that fell out, holes drilled etc. I had several. Also check for leaks at all the pipe connection points. There was a wind tunnel video a while back, i bet if they ran the smoke out of the exhaust that too would have been interesting...
Old Sep 14, 2010 | 09:15 PM
mj9311's Avatar
mj9311
c. wear a mask
d. rebuild carb
e. replace exhaust
Old Sep 15, 2010 | 09:47 AM
Hadez's Avatar
Hadez
on my vette...never have noticed a problem
on my buddy's 68 Mustang Fastback...Hell Yes!!! I about tossed my cookies one time we were in stop & go traffic and all the fumes built up in his tailgate area getting into the cabin through the rear hatch.
Old Sep 15, 2010 | 01:51 PM
79c3man's Avatar
79c3man
what type of exhaust manifolds are you guys using with the side pipes on c3 vette
Old Sep 15, 2010 | 02:03 PM
MyRed69's Avatar
MyRed69
Not to hijack the thread; this is the setup I bought to put on but...
I'm thinking real hard about b71vette's setup described in this thread:
http://forums.corvetteforum.com/c3-t...ide-pipes.html
and trying to figure out where I can run a crossover tube, and if it's really necessary.
Old Sep 15, 2010 | 02:08 PM
TERRY CLARK's Avatar
TERRY CLARK
Only bad odor is burning flesh with Hookers!
Old Sep 15, 2010 | 05:12 PM
redman76's Avatar
redman76
St. Jude Donor '09
I've got Hookers with the STS baffles and have a very strong odor. I'm pretty sure I have a lean condition and some carb issues. I've read that lean conditions can cause the odor too. Timing is ideal and I've adjusted the air screws for max vacuum. My next plan is to rebuild my quadrajet which I KNOW has issues and needs larger jets.
To sidepipe fumes
