Leaky valve covers
Old Sep 13, 2010 | 10:24 AM
ladder13's Avatar
ladder13
Default Leaky valve covers
What's the best gasket to use on my 80' L82 small block? Thanks
Old Sep 13, 2010 | 11:01 AM
MrJlr's Avatar
MrJlr
Might be lame....but I like Fel-Pro...
Old Sep 13, 2010 | 11:15 AM
7T1vette's Avatar
7T1vette
Fel-Pro 'combination' gaskets, which are a mixture of sythetic rubber and cork, IMO. Both sealing surfaces need to be flat...both need to be clean (as in NO oil/grease and wiped clean with lacquer thinner or gasoline, etc.). Sit the gasket in place, sit the valve cover on top, use load spreaders (if they were required for your engine), insert bolts, then torque ALL bolts to 30% of load...then to 70% of load...then to final torque. After that, they will not leak...unless there is another physical route for the oil to pass through.
Old Sep 13, 2010 | 11:32 AM
Ironcross's Avatar
Ironcross
Almost any brand will work, its the preparation that's critical....You need clean and flat surfaces to start with and a real good hard setting adhesive spread over the valve cover lip. Then and lay the gasket into the cover and allow to completely set the full distance around the cover. If you have to use a weight to accomplish this do so...3M yellow weather stripping cement #8011 I believe, is my glue of choice as its almost bullet proof to get off....Held firmly in the cover prevents accidental bumping against the rockers and not getting the gasket sealed completely all over....And a note, Silicone is not a glue, its a gasket that's almost always incorrectly used for an adhesive.....
Just grease the head surface and apply the valve cover with the gasket firmly stuck in the cover......you may have to re-tighten the screws a few times but that's normal with cork style gaskets
Old Sep 13, 2010 | 12:17 PM
Paul L's Avatar
Paul L
FelPro makes a gasket with hard nylon inserts at the bolt holes. You cannot overtighten the bolts and introduce a "squish" factor.
Old Sep 13, 2010 | 12:36 PM
JimT's Avatar
JimT
Amen for the Felpro gaskets with metal inserts. They are the best!
Old Sep 13, 2010 | 12:59 PM
SteveG75's Avatar
SteveG75
I use the Mr. Gasket Ultra Seals. I also have nice rigid aluminum valve covers. ARP studs make install easy and ensure that the gasket does not shift. Not stock but works great.
Old Sep 13, 2010 | 01:21 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I love fel-pro also but I use the black neoprene ones with the bolt inserts, there cheap and they work great. Ron
Old Sep 13, 2010 | 03:13 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Correctamundo
Old Sep 13, 2010 | 04:25 PM
7T1vette's Avatar
7T1vette
With the correct prep and a good quality gasket, you don't need [and shouldn't use] any adhesive or sealant on them.
Old Sep 14, 2010 | 04:42 PM
ladder13's Avatar
ladder13
What would a shop charge for both covers? How many hours or would they do flate rate?
My shop charges $95 per hour in the NY suburbs.
Old Sep 14, 2010 | 05:13 PM
Paul L's Avatar
Paul L
I don't know about flat rate but it is a one-beer job: about 15 minutes.
Old Sep 14, 2010 | 07:31 PM
7T1vette's Avatar
7T1vette
Except that most shops have a "1 hour minimum" charge.
Old Sep 14, 2010 | 07:35 PM
ladder13's Avatar
ladder13
Stop by, I'll give you a case of beer
Old Sep 15, 2010 | 12:04 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
With stamped steel valve covers I'd use a quality cork or composite gasket with RTV around the entire perimeter on the valve cover, then use some RTV on heads on the lower rails and back corners where oil pools. When valve covers leak, that's where it will happen 9 times in 10.
I've not had any luck whatsoever with stamped steel valve covers and the expensive neoprene (blue) gaskets with the integral washers that prevent over-tightening. They're great with aluminum valve covers which are far more rigid. RTV isn't used with these gaskets.
With stamped steel you need to rely on RTV to help with the inherent uneveness of stamped steel.
The gray RTV is good. It's much easier to remove and clean up when it's time to R&R parts.
As a side, leaking valve covers at the rear of the engine have led to more misdiagnosed leaks than anything. People pull their tranny's to replace crank seals, or pan gaskets, etc.
Put RTV to work for you.
Good luck!
To Leaky valve covers
