birdcage opening
Old Sep 15, 2010 | 01:18 PM
Wood1980's Avatar
Wood1980
Default birdcage opening
I am installing HushMatt in the car and was considering if I should put a piece over the opening by the foot well which is ultimately covered by the plastic foot well cover? I am wondering if that will trap any moisture that may get into that area - hence not allowing it to vent? I realize that moisture is not suppose to be in there, but am working towards making the car water tight.
Next question: the plastic foot well covers have carpeting on them....is that factory or should they be just plastic/no carpet?
Thank you!
[IMG][/IMG]
Old Sep 15, 2010 | 03:47 PM
Alan 71's Avatar
Alan 71
Hi W,
I believe that the kick panels had carpet on them starting in the 78 model year.
I don't see what help the heat barrier would be at that location.
Regards,
Alan
Old Sep 15, 2010 | 04:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...I believe that the kick panels had carpet on them starting in the 78 model year....
Yep
...I don't see what help the heat barrier would be at that location.
Sound deadener -- if you want, you can put Hushmat inside that area.
May not do a whole heckuva lot.
Old Sep 16, 2010 | 08:36 AM
Wood1980's Avatar
Wood1980
Will put new carpet back on the kick panels - thank you!
Old Sep 16, 2010 | 04:42 PM
Alan 71's Avatar
Alan 71
Hi Mike,
My eyes read HUSH but my brain thought COOL!
Getting old has very few joys!
Regards,
Alan
To birdcage opening
