PS Pump Grind on maximum left.
Old Sep 15, 2010 | 06:04 PM
Raider74's Avatar
Raider74
Default PS Pump Grind on maximum left.
Hi, haven't been on in a while my C3 has been working beautifully every day but I recently noticed a new "noise." On a far left turn Just before the wheels hit the stop the power steering pump seems to grind.
Some background info: I have a brand new power steering pump, not rebuilt, with brand new lines going to a brand new control valve. Only the ram is original but it has no leaks and works fine. After installing and filling the system I unhooked the ram from the rack and worked all the air out of the system.
What I suspect: I did NOT balance the control valve because the warranty info specifically said that if I remove the cap for the adjuster then the warranty is voided. I suspect that it is not properly balanced because this "grinding" does not occur on a right turn to the stop.
Why would a company make the warranty void if you adjust the balance? That seems exceptionally bizarre unless they are so extremely confident in their pre-balancing of the control valve. Any thoughts?
Old Sep 15, 2010 | 07:07 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Put the front of the car up on jack stands. Start the car and see if the wheels make any kind of motion to the left or right. This should tell you if the valve is centered well enough.
If you want to go further you could remove the wheels, break the ram loose of its end point mount and then start the car and see if the rams stays put. If it moves one way or the other, then it is time to remove the cap and center the valve.
It has been quite a while since I have performed the centering of the valve so if I am wrong someone please correct me or add to this to make it correct.
Old Sep 15, 2010 | 09:32 PM
7T1vette's Avatar
7T1vette
At any point in the range of steering motion, the P/S system can achieve equilibrium except at the extremes of the range (on either side). It doesn't really "grind", it just 'deadheads' the pump because it continuously calls for more pressure (even though it's giving its "all"). This is a normal behavior of the C3 P/S system. To prevent that noise...don't take it all the way to the stop in either direction.
Old Sep 16, 2010 | 05:07 PM
Raider74's Avatar
Raider74
*sigh* I was afraid I would get this answer... Well Thanks for the info guys I guess Ill stop trying to make residential u-turns in one shot...
Old Sep 16, 2010 | 06:04 PM
Shark Racer's Avatar
Shark Racer
Mine groans, more so than grinds.
To PS Pump Grind on maximum left.
