I have searched for information with no definative answer to try to find a paint that will give me a 'cast iron' look on the calipers, master cylinder, cross shafts, rearend, drive shaft and 4 speed transmission. I would like to by in a quart can to apply through a spray gun.
Any tips out there are appreciated.
Dano,
If you're trying to look 'original, the calipers should be painted semi flat black. M/C is usually semi flat black too. Transmissions should be natural aluminum
The calipers on the early C3's were not painted...they were bare cast iron. So, I believe the thought of painting them "cast iron" color is a good one.
VHT makes a 'cast iron' color paint that is also heat resistant. But, to cure it completely, you have to bake the painted part at a relatively high heat. To do so with the calipers, you would have to remove it and pull the pistons and seals out. [not a big deal, if they are already off]
Seymour makes a "cast blast" spray paint which is very good also. As far as getting a can of paint that you can put into your own sprayer, I'm not familiar with any sources for that. I'm sure a pro auto body paint supplier could provide you with that, however.
Hi Dano,
You might want to go to the EASTWOOD site. They sell a large selection of restoration tools, supplies, and paints.
You can request a catalogue which will show the WIDE range of paints they sell for various applications on the chassis and running gear along with everything else they sell.
Often having the various chassis parts finished in more appropriate finishes gives a very nice look.
Good Luck!
Regards,
Alan
PS: I, too, would expect the brake calipers to be painted black except on the machined surfaces. The same goes for the master cylinder which I believe had 'foundry' black on it.
I thank you all for the quick advice and suggestions, much appreciated. I will research the sites/suppliers you all have offered and see what is available.
