What is this hose for?
Old Sep 17, 2010 | 01:52 PM
Stooney's Avatar
Stooney
Default What is this hose for?
I've included 2 images outlining the hose in question. It goes in somewhere under the carburetor but is not connected anywhere on the other end. Car runs fine as is. I'm curious what this is for.
Old Sep 17, 2010 | 04:36 PM
gerry72's Avatar
gerry72
It could be for the transmission controlled spark (TCS) or the EGR valve. Not having any idea what year car we're talking about (and it ain't in your profile) makes it difficult to say.
Old Sep 18, 2010 | 04:49 AM
c31980's Avatar
c31980
the other end connected to what ?? that will help to id
Old Sep 18, 2010 | 08:53 AM
Paul L's Avatar
Paul L
The year of the car would help. Normally with a stock Q-Jet that would be the ported spout pulling vacuum to the EGR valve through the thermal vacuum switch (TVS). On a Holley as shown I do not know.
If that hose is not connected to anything you have a serious vacuum leak.
Old Sep 18, 2010 | 12:43 PM
Stooney's Avatar
Stooney
Sorry for lack of details. I will update my profile in a minute.
The car is a 1980 with a 305.
Old Sep 18, 2010 | 01:19 PM
7T1vette's Avatar
7T1vette
Until you identify the purpose for that hose...and determine whether you need it or not...either plug the other end or remove the hose and cap the carb fitting.
Old Sep 18, 2010 | 02:37 PM
laytonkopplin's Avatar
laytonkopplin
well my holley is the same but I capped it because its a vac hose option holley gives you but on my set up I didn't need it open nor hooked up to anything so I put a cap on it and now the car is more responsive
Old Sep 19, 2010 | 02:28 PM
Paul L's Avatar
Paul L
Well, is there an end to the story?
Old Sep 19, 2010 | 04:51 PM
laytonkopplin
no I just capped it and everything seems fine
Old Sep 19, 2010 | 07:05 PM
Paul L's Avatar
Paul L
OK, nice to see a good ending.
Old Sep 20, 2010 | 11:40 AM
Stooney's Avatar
Stooney
Looks like I will be capping the carb fitting then.
In an effort to learn more, what is involved with a 'vacuum leak'? What does that mean exactly?
Old Sep 20, 2010 | 01:23 PM
gerry72's Avatar
gerry72
A vacuum leak is unmetered air (air not going through the carburetor metering to be mixed with fuel) going into the intake system.
Old Sep 20, 2010 | 02:29 PM
Paul L's Avatar
Paul L
Generally leading to a lean condition.
To What is this hose for?
