Incorrect valve lash
Old Sep 21, 2010 | 10:56 AM
billla's Avatar
billla
St. Jude Donor '14
Finding zero lash is finding the absence of resistance, so I can't see how it helps to have more resistance. Have you taken a hydraulic lifter on the bench and tried to push the cup down?
But 'nuff said from me on the topic overall - to each to their own
Old Sep 21, 2010 | 11:19 AM
7T1vette's Avatar
7T1vette
Actually, you search for the point where 'resistance' is just encountered. That is where the spring [and oil thickness] begin to come into play. Now, if you can identify that point before you actually get there, you are a better mechanic than me.
Either way...it's all good.
Old Sep 21, 2010 | 12:33 PM
billla's Avatar
billla
St. Jude Donor '14
I guess it's what you mean by "resistance" - the first hint of drag indicates the absence of clearance between the lifter cup and the rocker cup, tranmitted by the pushrod - so the cup does not actually move. I think we'd agree that any movement of the lifter cup is by definition preload.
Getting zero lash right as the starting point to preload is the key; not getting this right is the most common cause of issues - regardless of the engine positioning method used. And regardless of the method for finding it, folks taking a little time on a Saturday to just play with zero lash, really get a feel for it is time well spent - better if there's someone standing there with them.
You're right, it's all good and there is definitely more than one way to skin a cat.
