Race Car won't start...
Old Sep 20, 2010 | 07:57 PM
Tumarr's Avatar
Tumarr
try turning the distributor in either direction while someone is cranking it. see if you get it to sputter a bit.
Old Sep 20, 2010 | 08:50 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
One trick when pulling a distributor is to line up the rotor with the fire wall that way it's easier to re-install. I'm with the other guys, you're probably of a tooth on the distributor.
BTW- Congrats on your child
Old Sep 20, 2010 | 09:16 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by brando1118
GrandSportC3,
Well, if you've got spark and you've stated you have good fuel pressure and even tried starter fluid, then the issue has to be timing.
Try this:
Unhook/remove the spark plugs
Get a compression gauge and hook it up to the #1 cylinder.
Get a timing light and link it to the #1 spark plug wire.
Hold your finger over the pressure release valve(if available)on the neck of the compression gauge.
Point the timing light at the face of the compression gauge
Remotely/or get a pal to turn the motor over.
You should see the compression gauge jump with every flash.
If it's delayed or off, then set her to TDC and reinstall the dizzy
Good luck.
I'll give that a try on the weekend if I'll get a chance.. Got very little time... I did check the spark again today and it's a VERY strong and visible spark (when pulling out the plug and cranking the engine)
Old Sep 20, 2010 | 09:18 PM
GrandSportC3
Originally Posted by BKbroiler
So you're saying that the engine has not run with the distributor in its present location, right? Definitely a timing issue then. I don't think one tooth off is close enough to start unless you really twist the distributor around.
I always take a lot of care when pulling the distributor. I mark exactly the way it came out (the position of the rotor when completely in the tunnel and the position of the rotor after pulling it out. That way, I have never gotten it wrong..
Old Sep 20, 2010 | 09:19 PM
GrandSportC3
Originally Posted by 427Hotrod
The carb is actually squirting fuel right? The bowls are full of fuel?
Congratulations on the new son! What's his name?
JIM
Fuel bowls are full and it squirts plenty of fuel..
My son's name is Alexander!
Old Sep 20, 2010 | 09:20 PM
HobbyPoor's Avatar
HobbyPoor
I fought with a issue just like this...come to find out my distributor was 180 degrees out
Old Sep 20, 2010 | 09:22 PM
GrandSportC3
I doubt that the distributor is off. I also did try to move it in either direction and tried cranking and nothing...
Old Sep 20, 2010 | 09:33 PM
Tumarr's Avatar
Tumarr
well I just delt with my brothers lawn mower not starting. it had fuel and spark and it was timed right. found out there was water in the fuel. flushed out the carb and it fired right up.
Old Sep 20, 2010 | 10:04 PM
...Roger...'s Avatar
...Roger...
If you don't mind removing the drivers valve cover to find TDC #1
bring your timing mark up on 0
#1 intake and exhaust should be closed
#3 intake and #5 exhaust will be open
if #3 and #5 are not open then bump the engine over 360 until the timing mark comes up again.
Old Sep 20, 2010 | 10:11 PM
GrandSportC3
Eliminated that cause by draining and re-filling the fuel system...
Old Sep 20, 2010 | 11:19 PM
RobRace10's Avatar
RobRace10
Originally Posted by pewter-FRC
put a new set of plugs in it
If the plugs got fouled by race fuel, they will never light the motor. They must be replaced, not just cleaned. They may spark some, but they are also shorting out. Race fuel is much harder to light off then pump gas, so the plugs have to be right. One of my race cars was terrible that way, wouldn't fire in cold weather and certainly if the plugs had gotten fouled, it would not start unless the motor was cranked over with plugs out to clean the cylinders with the pump turned off and then new plugs installed.
Old Sep 21, 2010 | 07:42 AM
GrandSportC3
I tried starting the car with a almost brand new set of #10 plugs (which I use when running a larger shot of nitrous) and then I tired a set of #8 plugs (which I use when running engine only or only a small shot of nitrous). The result was the same.. The #10 plugs only have 3 runs on them.. Not really enough to foul them or could I be wrong?
Old Sep 21, 2010 | 08:16 AM
  #33
...Roger...
Can the retard switches be unplugged to isolate a problem there ?
Is the dist dependent on the box to start , if not can the box be unplugged until you sort out the "no start" ?
  #34
noonie's Avatar
noonie
Why don't you just borrow a stock hei dist to test. Easy 1 wire hookup and if nothing else use starter fluid. It should at least fart and eliminate the ignition as a problem.
Sometimes those fancy ign boxes fail in strange ways.
Forgot this, hook it directly to the bat pos to eliminate any switches etc.
Old Sep 21, 2010 | 08:28 AM
  #35
The Money Pit's Avatar
The Money Pit
My 406 is not a race motor (close though), and has a Proform main body on the carb (No choke). One time I had a time of it starting it after it sat for a while. Cranked on it till the battery was almost dead. The next day I went in the garage and flipped the key just to see if it would crank,....and it started right up. The only difference was the previous day it was below 40 degrees out, Since then I have noticed it's tougher to start when the temps out are below 40.
Carbs,.....Gotta love em,......
Old Sep 21, 2010 | 08:31 AM
  #36
GrandSportC3
It's not that simple.. I would have to find all the manuals again for all the components.. I wired that 3 years ago and have no idea how to eliminate components without having the wiring diagrams. I doubt that there is a problem with any of the components as I get a strong spark on all 8 cylinders..
Old Sep 21, 2010 | 08:33 AM
  #37
GrandSportC3
Unfortunately, I can't hook up just any distributor as my engine is built on a Dart Iron Eagle block with raised camshaft and I can only use a adjustable sleeve distributor and those are pretty expensive. A standard distributor can't be tied down as it will sit too high..
To Race Car won't start...
Old Sep 21, 2010 | 08:36 AM
  #38
...Roger...
I understand the strong spark but is the spark at the right time ?
Old Sep 21, 2010 | 10:25 AM
  #39
PuddleJumper's Avatar
PuddleJumper
It's either timing or bad plugs. One thing to consider is are the plugs firing when there in the cylinders,
I'll post a video to watch that explains what I'm trying get at if I can find it
Old Sep 21, 2010 | 12:09 PM
  #40
GrandSportC3
I agree that this sounds like the problem.. I'll probably end up pulling the distributor again on the weekend and setting it to #1. The way I usually do that it to take the drivers side valve cover off, bring the balancer to ZERO and make sure that the #1 valves are closed (that way I'm sure that I'm not 180 degrees off). Then I set the distributors rotor to #1 and try cranking it. However, won't have time to do that during the week.. WIll have to wait for the weekend..
