Race Car won't start...
Old Sep 28, 2010 | 03:15 PM
  #81
brando1118's Avatar
brando1118
Fingers Crossed "X"
Old Sep 28, 2010 | 04:18 PM
  #82
68 NJConv 454's Avatar
68 NJConv 454
Originally Posted by GrandSportC3
I've already measuered the power supply to the MSD bos and all looks fine.. Can't measure during cranking as I'd have to wire a remote starter.. Right now, I can't crank and measure at the same time due to that
If you have a Sears around you run out and pick this up...Actron Remote Starter Switch Cp7853 $12.99. This thing was well worth the few bucks when i was having similar issues as you this year trying to start by big block after sitting for 3 months. Mine was a fuel system issue. http://www.sears.com/shc/s/p_10153_1...&blockType=G21
Good luck!
Once you get'er going lets hear some info on what you'd be willing to sell it for and what its got into it.
Old Sep 28, 2010 | 06:12 PM
  #83
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
Just so that you have checked everything possible to enable the engine to fire up...do you have any hairline cracks in your intake manifold, or any of the gaskets look questionable on the carb and manifold assembly. Spray a little oil around all of the gasket areas...and try to give her a start... I twice had problems such as yours...#1 hairline crack
from a over tightened bolt...the #2 was corrosion of the water passages on the aluminum
manifolds. just a thought...you might have allready inspected this possible area of concern. Best of Luck!
Old Sep 28, 2010 | 08:48 PM
  #84
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Olivier,
after trying to crank it have you pulled a plug to see if they are wet with fuel?
Neal
Old Sep 28, 2010 | 10:16 PM
  #85
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Good luck!
Will see when I'll have a chance to get the switch during the week.. Hooking it up won't happen before the weekend..
Old Sep 28, 2010 | 10:19 PM
  #86
GrandSportC3
I'll check for cracks but I doubt that this is the issue. Don't think that the water passages could cause a problem as I'm not even running the water pump.. I'd only turn on the water pump (electric) once the engine is running
Old Sep 28, 2010 | 10:20 PM
  #87
GrandSportC3
Originally Posted by chevymans 77
Olivier,
Neal
Didn't notice any fuel on them but I'll check again when cranking again..
Old Sep 28, 2010 | 11:03 PM
  #88
OMF's Avatar
OMF
Is there any way the plug wires have been removed and installed again one hole out???
Old Sep 29, 2010 | 12:40 AM
  #89
PuddleJumper's Avatar
PuddleJumper
what kinda timeing gears do you have? ie one bolt, is it a adjustable gear set ect?
Old Sep 29, 2010 | 08:53 AM
  #90
GrandSportC3
I haven't messed with the plug wires since I raced the car the last time in 2008...
Old Sep 29, 2010 | 08:54 AM
  #91
GrandSportC3
I'm not sure.. I did not build that engine myself. I'd have to look up in my records on what the builder used..
Old Sep 29, 2010 | 09:09 AM
  #92
PuddleJumper
it could be of the quick ajustible type and it could of moved a few degrease
Old Sep 30, 2010 | 03:13 AM
  #93
Thmprr's Avatar
Thmprr
Despite the fact that you have seen spark occurring, I would borrow another MSD 6AL unit and try it. I have had weird things happen with them myself.
Old Sep 30, 2010 | 10:53 AM
  #94
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
They need a good ground, not grounded to the bolts on your intake or some location like that
Old Sep 30, 2010 | 11:31 AM
  #95
eastltd's Avatar
eastltd
Do you have a crank trigger on your MSD that may be sending a faulty signal?
Old Oct 1, 2010 | 04:11 PM
  #96
68 NJConv 454
Get that beast running? the suspense is killing me and apparently a few others on here.
Old Oct 1, 2010 | 04:17 PM
  #97
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Well, there's always AAA.
To Race Car won't start...
Old Oct 1, 2010 | 04:34 PM
  #98
Tim81's Avatar
Tim81
Here is a thought, just had this happen to my buddies circle track car. He just bought the car and trailered it home, tryed to start the car no-go. Carb was getting fuel and the spark was nice and white. He is running a modified Qjet and I noticed the carb did not have a choke butterfly on it. Held a rag over the carb throat and she fired right up. Just a thought, I hope you get it running soon...Tim
Old Oct 1, 2010 | 05:01 PM
  #99
LeSkid's Avatar
LeSkid
I'm a forum noob and not nearly as mechanically inclined as most who have contributed on this thread.
That being said, since 'all' the basics have been covered and you're still not having any luck, could the problem be after the engine? My only potentially relevant experience like this was an old Buick I had that ran tip-top-perfect. After sitting for a while, it wouldn't start. Dead. Strong spark, good fuel pressure yada yada yada.....
Turns-out back pressure in the exhaust was the culprit. My catalytic was blocked solid. But I imagine your race car is dual exhaust so I doubt this is the case on your race car....
Maybe some prankster shoved bananas in your tailpipes?
Hey, it's all I got.
Old Oct 1, 2010 | 05:09 PM
  #100
...Roger...'s Avatar
...Roger...
Maybe mice ? Fuel + spark - air ?
