headlight brights flicker
Old Sep 22, 2010 | 08:39 AM
bdvtwin's Avatar
bdvtwin
2nd Gear
Default headlight brights flicker
I have a 74. The low beams work fine. When the brights are turned on they flicker. Sitting still,moving, engine off, engine on doesnt matter.It seems to happen when the brights warm up(flicker/fade in and out). No loose wires that I can find. Is there some power relay that may be bad????????
Old Sep 22, 2010 | 08:57 AM
Mikes*Corvettes's Avatar
Mikes*Corvettes
This thread may help you out.
http://forums.corvetteforum.com/c3-g...hts-flash.html
Old Sep 22, 2010 | 01:04 PM
bdvtwin's Avatar
bdvtwin
2nd Gear
Thanks for the heads up. Sounds like this could be the problem. Thanks again!!
To headlight brights flicker
