window won't move
Old Sep 22, 2010 | 02:17 PM
dburgjohn's Avatar
dburgjohn
Default window won't move
the power window in my 81 won't move. Press the switch up or down and the lights dim and you can hear the vent fan slow. But if I put battery charger leads directly on motor (motor is less than 1 year old) the window goes up and down just fine.
My first guess is bad contacts in switch. Does anyone know other areas on the 81 that might need checking?
thanks again
Old Sep 22, 2010 | 02:48 PM
Shark Racer's Avatar
Shark Racer
Is it one window or both?
If it's just one, then I'd go with the switch. If it's both, I'd examine the relay.
Old Sep 22, 2010 | 03:09 PM
dburgjohn's Avatar
dburgjohn
Default just passenger
just the passenger side is having issues
Old Sep 23, 2010 | 10:56 AM
dburgjohn's Avatar
dburgjohn
Got side off console, how does switch come out?
Old Sep 23, 2010 | 04:39 PM
Stooney's Avatar
Stooney
There are 2 phillips screws, one at the top and bottom of the switch. Remove those and the switch is loose. Pull the switch off the plug (might take a good pull) and you're set.
Old Sep 23, 2010 | 05:04 PM
Red70vette's Avatar
Red70vette
I recently had the same problem with my drivers side window. It ended up being one of the emergency brake console screws had touched the wire and shorted it out. Removed the screw and it worked fine. Needed to tape up the wire to seal it.
Old Sep 23, 2010 | 09:51 PM
dburgjohn's Avatar
dburgjohn
contacts burnt. took it apart. The shrink wrap jamed around the bottom shows I am not the first to make this repair. With a little luck and JB weld I will still make the local show saturday. With a chance of rain, not way I was going with a window that would not go up even if it was just the 7 miles from home to the middle of town.
Old Sep 30, 2010 | 09:41 AM
dburgjohn's Avatar
dburgjohn
Default wrong
I was wrong. New switch did not help. Now trick of jumping at wire plug won't make it go anymore. Ordered a new window motor :P
That makes 3 this car has gone through
Old Sep 30, 2010 | 10:30 AM
Rebelrob's Avatar
Rebelrob
Hey Dburg, check out this forum/thread from the cac. I bookmarked this a while back, because I figured I would need it one day. Maybe this can help, maybe not, but worth a read.
http://www.corvetteactioncenter.com/...-switches.html
Let us know.
Sort of wish my car had manual crank windows.
Old Sep 30, 2010 | 05:29 PM
dburgjohn's Avatar
dburgjohn
Default what went bad????
pulled motor, hooked heavy charger to motor and it works, when I try in car, the lights just dim and it does not move.
Bad motor? Bad wire?
Old Oct 1, 2010 | 11:04 PM
dburgjohn's Avatar
dburgjohn
Default and the answer is...
Both were bad. My guess is the heaver draw of the failing motor burnt the switch. Both switches had been pried apart and glued back before. New switches, motor and gear and it's good to go.
This is motor #4 in this car in the last two years. 1st was original, 2nd was bought as a replacement from Advance. It failed inside warrenty and got another (#3). That one has now failed and I went with OReilly. They probally all come from the same place, but maybe.
To window won't move
