Tips for installing long tube headers on a C3
Old Sep 23, 2010 | 09:18 AM
75coupered's Avatar
75coupered
Default Tips for installing long tube headers on a C3
Hi all,
Just wanted to share some of my observations from installing a set of Headman long tubes on my 75, that may be of use to others.
I've read countless posts in doing my own preparation reseach of how easy it was to install headers in a C3. "it's a couple hours of work", "they slip right in" etc.
Well for starters not all C3's are the same in terms of engine options, tranmissions and auxillary components over the years, so before you jump into this job thinking it's a walk in the park, here are a few notes.
Mine is a 75, 4-speed, with power steering, and A/C.
Soak the manifold bolts with PB Blaster or some penetrating oils for a few days prior to help loosen things up especially if the manifolds have never been removed.
Remove comonents. On the drivers side i is easier to install the header from below if you remove the following components: Alternator, dip stick tube, spark plugs and z-bar clutch assembly if a manual tranny.
On the passenger side it is helpful to remove the spark plugs and the starter.
While you are in there and the exhaust is out it's a good time to replace motor mounts an address other items.
Other notes for preparing for the job, get your reducers and exhaust flex pipe to make the union to your exhaust as the headers won't line up otherwise.
hope these tps help
Old Sep 23, 2010 | 09:52 AM
damoroso's Avatar
damoroso
See it was an easy bolt in!! I've found most of the time bolt in means if you have a grinder, welder, drill press and about three times the time and 20% more money than planned....then it's a "bolt in" job!!
Old Sep 23, 2010 | 10:32 AM
75coupered's Avatar
75coupered
damoroso,
Yup, just a bolt in
Another thing to mention is modifying the AC compressor mounting bracket to fit around the header tubes is you have the old A6 compressor. Hooker makes a steel mounting bracket that can also be used in lieu of modifying the stock one.
Best to all doing this job, it will take anywhere from a few hours to a few days depending on what you encounter.
Old Sep 23, 2010 | 07:12 PM
jb78L-82's Avatar
jb78L-82
Buy a set of McJack's shorty headers-an exact duplicate dimensionally of the OEM cast iron manifolds and hook right up to OEM true duals-Bolt in!!!
Old Sep 23, 2010 | 09:10 PM
81pilot's Avatar
81pilot
To me what you described is a bolt in job, and it was exactly how I did mine for the most part. Nothing is simple it all takes a little work.However, If I draw blood on more than three knuckles then I don't consider it easy anymore. :O)
Old Sep 23, 2010 | 10:16 PM
mj9311's Avatar
mj9311
hahaha nothing is ever simple and once you start something you always get the " well while i have this out i might as well..." and that list will go on until your out of money
Old Jun 9, 2019 | 09:28 AM
vasman82's Avatar
vasman82
Cruising
I hear that! I started with having to change my water pump on my 82 and now doing hooker comp headers and new everything that i can replace along the way
To Tips for installing long tube headers on a C3
