need power steering
Old Oct 26, 2010 | 10:46 PM
sgm2004's Avatar
sgm2004
Originally Posted by 76yellow
Hey sgm2004, I'll take it !
76yellow are you going to drive to Northern Virginia to pick it up? A long ways to drive for it.
sgm
Old Oct 26, 2010 | 10:58 PM
pauldana's Avatar
pauldana
Originally Posted by sgm2004
Did same to 75 best thing I ever did to car. Went through that nut roll with steering boxes. A/D/R I cannot see why everyone hangs on to a stock system or update to a modern 1990 Delph system (WHAT 1990 modern?) Steeroids is way to go anyone want a stock system off a 1975 corvette? With fairly new control unit and cylinder and new hoses. Heck I'll give it to you. I will sell the steering box for $50 though. Just my 2 cents as always. Hope I didn't hurt any steering box peoples feelings if I'm sorry. Thanks
R/S
sgm
yea... I through mine in the trash can.... never looked back..
Old Oct 27, 2010 | 12:33 AM
johnrodz's Avatar
johnrodz
I found the problem .it was in the new hose. The hose had a defect idside and was not leting fluid pass through to the controle valve .I removed them and blew them out to see if there was trash in the line even though I sprayed the conections with brake clean to remove any posable trash that could be in the area. One would not pass air in either direction got new ones from zip and everything works great . Problem solved thanks everyone for your responces. John/Johnrodz
Old Oct 27, 2010 | 09:50 AM
wombvette's Avatar
wombvette
Thank goodness. Now maybe this hornets nest you stirred up will settle down.
Old Oct 27, 2010 | 09:53 AM
7T1vette's Avatar
7T1vette
There, now.... Wasn't that easier than replacing all the new stuff with other new stuff?
Of course, it confirms the 'root cause' of the poster's problem being the crappy quality of new parts, these days. A plugged up 'new' hose. Wow...
Old Oct 27, 2010 | 12:52 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Originally Posted by 7T1vette
The Corvette did not use the same power assist system that other GM cars used [although other models did use that same system], but that DOES NOT mean that the Corvette power assist was weak, faulty, or prone to failure. I had new C3's, and while its power assist was not as strong at a dead stop as other designed systems, once the car was moving at all it felt the same as new full-sized cars. So, I don't buy ZIP's assessment of the C3 power assist system.
Frankly, I think you got a junk control valve from ZIP. And I have no complaints with ZIP or its service [normally]. But a C3 power assist system with all new components and no actual assist being produced can only be due to a couple of things...and the most likely is a bad control valve.
Now, if ZIP can tell you [with a straight face] that they actually tested the performance of your valve when they receive it from their supplier, I guess you'll have to accept their story. But, I don't believe they do 100% {if any} testing on rebuilt control valves. And I would bet a good amount of money that their supplier doesn't either. Considering how much money you've already spent with them, they should help you out and swap the control valves if you pick up the shipping costs. That's my 2 cents....
First off to the OP I am glad you resolved the issue, what was stuck in the hose out of curiosity.
71 Vette, yes every valve is tested before it leaves the manufacturer which is in the US. The assesment I give is because of what you believe is power assist and what someone else believes are two different things. It is like comparing opinions of Elkhart green in 72.
What I said is if you can turn the wheel from lock to lock with the car sitting still it is working, are you saying I am wrong about that? I can't even begin to account how many cars and valves I have installed, my findings come from experience with the massive number of Corvettes that I work with, not from one car that did this or that. I have had cars with extremely low miles and the same with high mileage and while the effort of the steering can be different, it is all the same in what I stated, if you can turn the wheel from lock to lock sitting still then it is working, If you can't, then Houston there is an issue and we need to start looking to see what is wrong. It could be a pump, lines, relay etc, but you also can't rule out human error when the parts are installed. I am trying to fix cars over the phone customer without being able to see what they working with, are the lines crossed etc. So for one I think the Domestic parts are great compared to what allot of other companies are selling. I still believe that my comments were dead on.
Justin
Old Oct 27, 2010 | 03:01 PM
7T1vette's Avatar
7T1vette
Justin,
I have re-read this entire thread, and it seems that my comments should have been more directed at the OP's description of what [he reported] ZIP told him, rather than what you actually stated in your post. My apologies.
But, you have to admit that finding an obstruction in a 'new' hose is a pretty "odd" find for a 'non-function' problem for the C3 power steering system. the probability of that being the case is likely less than 1 in a 100 compared to the pump and/or control valve being the cause for that fault.
My assumption was that 'new' parts bought from ZIP were the OP's problem. Unless the hoses were purchaed from ZIP, as well, it turns out that this failure was NOT ZIP's responsibility. Apologies for my erroneous assumption. :o
P.S. I'm glad to find out that someone in the aftermarket parts supply network expects functional parts to be tested.
Old Oct 27, 2010 | 04:05 PM
Zip Corvettes
Apology accepted.
We spend a ton of time making sure our parts are what we say they are.
Yes many times a supplier can really wreak havoc on that idea, but we stand behind what we sell and when there is an issue I am there to help solve it. The biggest problem I run into is new owners thinking of how something should work instead of listening to someone who knows how it should work. I understand where this comes from, because there is so miss information out there by some vendors. I look at like when I go into the Doctors office, I try to listen and not give advice.
Yes I do find it odd that there was something in the line. Now it could have been something from the packing in the box, who knows it could have been anything. I try to and it is a good habit to get into whenever you have new or even old lines you blow them out. This will prevent something like this from happening.
Justin
Old Oct 27, 2010 | 08:41 PM
johnrodz's Avatar
johnrodz
this realy pissis me off. You talk like I dont know **@* I have restores cars now for over 35 years and over that time I have seen a lot of defected parts from a number of companys I did not ask for replacment parts from zip just asked for help I was treated like a rookie as if I knew nothong about automotive technolage . My frend Justin was allways there for all i needed and I respect his efforts in my behalf .The coments about the power steering not having worked all that well new came from some one there at zip that i do not know his name or I would give it It was his coment that I didn't like not Justin I have baught parts from zip for a number of corvett restorations I have done in the past . In the past Wayne Walker was my go to there and now I try to go to justin for all I need .Im sorry for all the confusion and wish Justin the best ..... John / Johnrodz
