75 C3 tilt/tele steering column exploded view needed
Old Sep 24, 2010 | 12:09 AM
Iggycat2009's Avatar
Iggycat2009
Default 75 C3 tilt/tele steering column exploded view needed
I went to the Willcox web site and cannot find an exploded view of a 75tilt/telescopic steering column. I took it apart and replaced the tube bearing and have the hub back on with the wiring harness installed .....and my memory is obviously not good because I cannot remember how the remainder of hub goes back together. .
My email address; brennan.farm@verizon.net
Thanks in advance.
Mike
Old Sep 24, 2010 | 12:38 AM
Scott Marzahl's Avatar
Scott Marzahl
Here you go:
http://jimshea.corvettefaq.com/?page_id=4
Maybe some of these photos will help too
http://blog.scottsvettetalk.com/2008...n-rebuild.aspx
Old Sep 24, 2010 | 07:02 AM
Jim Shea's Avatar
Jim Shea
Here are the addresses for two pictures. The first is a blowup of the 1969-76 T&T steering column that Saginaw manufactured. The second blowup is of a 1977-82 the steering wheel, telescope lock, and horn parts that Chevrolet supplied. The 1977-82 steering wheel is different from the early years but the telescope lock and horn parts are all the same.
http://jimshea.corvettefaq.com/wp-co...prev26de09.pdf
http://jimshea.corvettefaq.com/wp-co...sRev08AU04.doc
I obviously don't know how to use the search feature on this Forum correctly. I tried to find my answer to a previous question just like this one but I come up with stuff that has nothing to do with "T&T" columns or "Jim Shea".
Jim
To 75 C3 tilt/tele steering column exploded view needed
