Blinking Headlights & Wiper Door
I'm sure someone out there has seen this problem before.
I have recently rebuilt and/or replaced all my vacuum operated equipment on my 1970 vette.
It's all back together now and working, except for the following oddity.
When I start the motor, the headlights and wiper door pop-up for a second or two then close again.
When I operate the light switch or wiper switch (with motor running), they open and close as they should.
It seems to be something with the amount of vacuum reaching the relay valves maybe or how quickly it is building vacuum? I have had no luck troubleshooting it though.
Any thoughts or experiences would be welcome.
Cheers,
BB
It can't be the check valve fitted backwards, for two reasons:
1. The valve can really only fit one way. It has one port on the manifold side, and two ports on the opposite side (one to the vacuum tank other to headlight switch / wiper solonoid).
2. If fitted backwards, nothing would work because there would be no vacuum to any components. As I mentioned above, both systems work fine, but blink when the car is first started.
Thanks anyway, but does anyone else have any ideas
BB
BB
I think we are both on the same track here. It seems to be a timming issue. How fast vacuum is building up on the signals side versus the control side of the vacuum system.
I have checked and double checked everything. My dash is out, so I know there are no pinch hoses, or leaking hoses there. Besides the headlight actuators and wipe door actuator, eveything else is new. Including the hoses, headlight switch, over-ride switches, wiper solonoid, and relays.
None of the vacuum hoses have clamps on them, and they don't from the factory, so i can't imagine a vacuum leak there.
Logic dictates that vacuum should build up much faster on the signal side due to the smaller diameter hoses and smaller components vs the control side which has to evacuate the larger diameter hoses and all of the vacuum tank!!!!
So there must be a leak somewhere ???? But where, and how do I find it.
Can anyone else suggest anything.
Cheers
BB
