Door panel screws ! Argh !
Old Sep 28, 2010 | 08:18 AM
Spitfire80's Avatar
Spitfire80
Default Door panel screws ! Argh !
1980 vette.
When purchased 4 years ago, the interior was redone and in top shape. (new door panels)
The bottom halfs seem to get lose all the time and I always have to tighten the screws.
Near the feet area, bottom corner near door hinges, it seems to require screws for the panel to be tight snug against the door....
Am I missing something here ?
Because of the slaming/closing the doors, everything losens after a while !
Is here any diagrams that can show me where there should be screws.
The panels came off and I don't see anything !
S80
Old Sep 28, 2010 | 10:18 AM
7T1vette's Avatar
7T1vette
The drilled hole in the door frame is probably larger than from the factory from years of removal/reinstallation. The best 'fix' is to put a wad of JB Weld [stick] epoxy putty behind the hole (with a little on the outside to keep it in place) then drill a smaller hole for the screw. The simplest fix is to install the next size larger screw.
Old Sep 28, 2010 | 10:38 AM
MrJlr's Avatar
MrJlr
JB Weld is
That's not Bubba at all....no one will ever see it....and it works great !
Old Sep 28, 2010 | 10:55 AM
avner's Avatar
avner
I put in the door frame a rivet nut (1/4"???) used a aelen head screw with big washer and cover it up with plastic that I found at home depot.
Its hold the panel very good and not tier the panel skin.
Avner
Old Sep 29, 2010 | 07:04 AM
Carlos840's Avatar
Carlos840
Or you can do it the Bubba way, like it was done to my car, just put a few self tapering screws wherever you feel like!
Damn you bubba!
Old Sep 29, 2010 | 09:18 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by MrJlr
JB Weld is
Fixed my toilet with the WaterWeld version, damn good stuff cures and hardens in oil, gas, water, oh yeah fixed a brake line leak with it too that lasted until I replaced all the lines, probably more than 2 years
To Door panel screws ! Argh !
