Frame restoration question?
Old Sep 30, 2010 | 09:10 PM
GT's 78's Avatar
GT's 78
Default Frame restoration question?
I'm almost ready to start removing the rust from my bare frame. I know I will be able to remove the rust on the outside but does anyone have any sugestions on how to remove the rust on the inside????
Old Sep 30, 2010 | 09:42 PM
SS164's Avatar
SS164
I sent my frame out to be dipped in a large tank of cleaning solution. This process removes rust on the inside and outside of frame. Cost was about $450.00 and the frame came out great. Not sure where you are located but the place that I used is located in Allentown PA.
Old Sep 30, 2010 | 09:54 PM
bigvette1's Avatar
bigvette1
Default Frame Strip
Take a look in the yellow pages for Redi-Strip. There may not be one in your town but within a trailor haul away. They do the total tank dipping and stripping.
Old Sep 30, 2010 | 10:23 PM
z10kl's Avatar
z10kl
I sand blasted my frame on a rotisery, turning it to get in all the openings from different angles. I know this didn't get all the rust off but It got some and the sand in there as I turned it to get it out I blew compressed air in the holes and kept turning the frame till all the sand was out.
Then I got a pump up garden sprayer from Lowes and put a rubber hose on the end to make it longer. I stuck it in the holes and sprayed POR in the frame and turned the frame many times till it was running out the holes. I feel I got a pretty good coat of the POR on the inside.
I then cleaned up the runs on the outside and painted the outside.
Old Oct 1, 2010 | 07:43 AM
GT's 78's Avatar
GT's 78
Thanks for the ideas.
Old Oct 1, 2010 | 12:51 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Just saw where Eastwood sells internal frame rust encapsulator with a spray nozzle for $19.99
Old Oct 1, 2010 | 12:55 PM
wan2run's Avatar
wan2run
You guys that dipped your frame - how do you then go back and coat/paint the inside once cleaned?
Old Oct 1, 2010 | 01:08 PM
skaping's Avatar
skaping
There is a coating process called autophoretic or autodeposition where they immerse the chassis in a vat and the coating molecules are attracted to the chassis. It is like powdercoating but in water instead of air. http://www.henkel.com/aquence-autophoretic-12623.htm The powder coater I use does this as a "primer coat" on chassis etc.
Old Oct 1, 2010 | 03:56 PM
SS164's Avatar
SS164
Ziebart did mine. I delivered my painted frame to them w/o any parts on it. Any overspray from the process was easily cleaned off with prepsol. Cost about $140.00 4 years ago.
ziebart.com
Old Oct 1, 2010 | 07:04 PM
7T1vette's Avatar
7T1vette
You should be able to locate a wire brush (like a bristle end) on a flexible wire that you can run into the frame rails for knocking off the loose stuff. Then you would want to spray the inside with some rust 'neutralizer' or 'encapsulator' to convert it to an inert compound. Some of the undercoating shops might do that kind of work. If you don't plan on driving it in the rain/snow/salt stuff, why worry about it now?
To Frame restoration question?
