1968 327/300 engine. Please help!
Old Oct 1, 2010 | 10:21 AM
cmjohn's Avatar
cmjohn
8th Gear
Default 1968 327/300 engine. Please help!
Does anyone know the cam max lift for double hump 2.02 1.60 heads? They are factory 291s.
Old Oct 1, 2010 | 11:40 AM
GeorgeS's Avatar
GeorgeS
I don't know the max lift, but I installed a Crane Z 274-2 cam in mine. It has 473/486 lift and I have no problems. Runs well.
Old Oct 1, 2010 | 01:29 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
It depends on installed height and coil bind height of the valve spring, and, of course, which cam is used. Don't forget to check other clearances such as retainer to guide, retainer to rocker, and valve-to-piston at overlap, etc.
Old Oct 1, 2010 | 02:34 PM
cmjohn's Avatar
cmjohn
8th Gear
Thanks guys. I guess in order to run say a .501 lift cam, I would have to rebuild the heads. I went to Comp Cams and they had a section where you tell them what you have and they will email you what they think will work best.
To 1968 327/300 engine. Please help!
