Temp sensor for trick flow heads
Old Oct 1, 2010 | 06:15 PM
Casey Griffin's Avatar
Casey Griffin
Default Temp sensor for trick flow heads
Im instaling a pair of trick flow heads on a 71 350 and im not sure what temp sensor to use or the correct spark plugs. any help would be appreciated.
Thanks Casey
Old Oct 1, 2010 | 07:18 PM
C3 Stroker's Avatar
C3 Stroker
I used the stock sensor in my Trick Flow heads in my '69 350....should fit in stock location. Trick Flow recommends which plugs to use (along with the proper gaskets) in their instruction info. The plugs were AC FR3LS....that number is now p/n #41-629. This is the recommended starting point.
Old Oct 1, 2010 | 08:13 PM
Casey Griffin
The sensor from my stock heads is not the same size it is larger any suggestions
Old Oct 1, 2010 | 08:24 PM
LB66383's Avatar
LB66383
What are you using for an intake manifold? Is there a place near the thermostat housing to screw in a temp sensor?
There are reducers available to adapt the sensor thread to the size of the hole in the head. I believe it's 1/2" pipe to 3/8" pipe but I could be off.
Old Oct 1, 2010 | 08:32 PM
'75's Avatar
'75
The choices are to put it into an available opening in the intake manifold or tap the hole in the head to 1/2 npt.
Old Oct 1, 2010 | 08:41 PM
...Roger...'s Avatar
...Roger...
Some have had luck turning down the threads to the smaller size.
Old Oct 1, 2010 | 08:58 PM
Casey Griffin
Default Thanks
BINGO! I have a edelbrock performer and it does, switched plug for temp sensor and off we go thank you.
Casey
To Temp sensor for trick flow heads
