76 Stingray emblem
Old Oct 3, 2010 | 06:01 PM
adam76texas's Avatar
adam76texas
Default 76 Stingray emblem
My driver's side Stingray emblem fell
off. I ordered a replacement from Eckler's.
The holes don't line up with the pegs on the
back of the replacement. I've got a few ideas
but I'm not sure which one to pursue.
All suggestions are welcome and appreciated.'
thanks,
adam
Old Oct 3, 2010 | 06:35 PM
Peterbuilt's Avatar
Peterbuilt
73 and early had 3 pins 74 and later had 4 pins call Ecklers and see if they mixed it up.
Old Oct 4, 2010 | 09:45 AM
oldsarge's Avatar
oldsarge
Don't do anything foolish, it probably is as Pete has said, not the right one.
Old Oct 4, 2010 | 12:23 PM
SteveG75's Avatar
SteveG75
Thought it was the other way around and early emblems had 4 pins. My '75 has the original fenders and original emblems and they have 3 pins.
Old Oct 4, 2010 | 04:27 PM
palmbeachvette76's Avatar
palmbeachvette76
My '76 has 3 pins also
Old Oct 5, 2010 | 07:21 PM
mj9311's Avatar
mj9311
mine to
Old Oct 7, 2010 | 07:19 PM
adam76texas
Just typed a response on cell and don't think it took!
Thanks for your responses! It does have 3 pins. Haven't
had time to call Ecklers and the 76 is in the shop geting a
new engine, radiator, rebuilt carb, trans, and on and on.
Does this mean that I'm not dealing with an original fender?
Cheers,
Adam
Old Oct 7, 2010 | 07:21 PM
adam76texas
Also, if I ordered another from year one would the
emblem come from the same maker? In other words:
is there a snow ball's chance that it would fit?
Thanks again
Old Oct 15, 2010 | 09:33 PM
SEVNT6's Avatar
SEVNT6
How about no pins..........
My '76, which I bought new and is still all original, had the Stingray emblems glued on at the factory.....
Old Oct 15, 2010 | 10:05 PM
SteveG75's Avatar
SteveG75
Nope, they all have pins.
The factory used the pins to locate them but all emblems had double sided tape from the factory. If your removed your emblems, you would find pins.
Old Oct 15, 2010 | 10:25 PM
SEVNT6's Avatar
SEVNT6
But I don't have any holes in my fenders...........
Old Oct 15, 2010 | 10:57 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Maybe there early 77 fenders??
Old Oct 15, 2010 | 11:46 PM
SEVNT6's Avatar
SEVNT6
Default Upon further reveiw.....
I do have holes. You can't feel them.......or the pins which are flush with the inside of the fender. But when I put a flashlight inside there and took a look, I could see two spots. One looks like it's behind the "T" and the other is behind the "Y"........
Old Oct 17, 2010 | 09:20 PM
Go Vette's Avatar
Go Vette
Cutting off the pins and using double-sided emblem tape will solve your problem. Some people use the tape even if the pins are aligned with the holes because the pins may not fit snugly in the holes.
Old Oct 22, 2010 | 08:29 PM
fgp73's Avatar
fgp73
I need to reattach the emblems on my '73...do they make 1/8 inch double sided emblem tape? I can't seem to find any
Old Dec 21, 2010 | 10:11 PM
adam76texas
Thanks for the responses. I ended up sawing of one of the them. You can see about 1mm of glue in a spot from the original. When I can muster up the courage to part with it for a weeks/months I'm having it painted, and the point shall be moot.
To 76 Stingray emblem
