Re-drilling wheels
Old Oct 7, 2010 | 09:03 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Re-drilling wheels
I have an opportunity to buy some magnesium wheels, but they are 4.5 bolt circle and I need them drilled for 4.75 bolt pattern. Is there anyone who can do this precisely accurately and safely?
Old Oct 7, 2010 | 09:29 PM
markids77's Avatar
markids77
You'll end up with oblong holes which are not the hot setup for staying tight. I do not believe it possible to weld magnesium as it is flammable, so closing the current holes before redrilling seems unlikely. I know you have been in search of some genuine "mags" for quite some time... I would pass on this set though.
Old Oct 7, 2010 | 09:35 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Redrill the hubs and put the 4.5" BC in the steel. Much stronger and the wheels stay cherry.
Rob
Old Oct 7, 2010 | 11:12 PM
meinthe73's Avatar
meinthe73
Are adapters out of the question?
Old Oct 8, 2010 | 10:59 AM
Solid LT1's Avatar
Solid LT1
Any competant machine shop should be able to redrill those wheels and install some steel lug nut seats (here is a link to someone offering them: http://www.prestigewheel.com/mainInserts.htm) I would caution you that magnesium fails internally and if the wheels are old, they should be X-rayed for cracks most aircraft repair services have access to X-ray machines for inspection of magnesium wheels.
If you want a new set of 15X8 magnesium wheels drilled to any bolt pattern needed these are for sale BRAND NEW! around $1000 each (Link: http://vintageeng.com/MG6A.html)
Maybe we can all get together and do a "group buy" for those Mags and get the price down to $750 each. I would seriously be willling to buy 4 for $3K, so if anyone else is serious about a set, lets start a list.
Old Oct 8, 2010 | 11:57 AM
gkull's Avatar
gkull
I work on historic race cars. Lots of magnesium parts. All your Hewland transaxles have magnesium cases. All front and rear bulkheads on Monoque chassis where the suspension frames attach are magnesium. Cosworth timing and valve covers. We weld and remachine these items all the time.
It's just like welding aluminum. You use inert gases. It is actually pretty hard to get big pieces of magnesium to burn. Shavings, powder, the curlings off a lathe are very flammable
Old Oct 8, 2010 | 05:36 PM
68 NJConv 454's Avatar
68 NJConv 454
Interesting.
To Re-drilling wheels
