Ceramic Spark Plug Boots??
Old Apr 1, 2002 | 06:25 PM
James's Avatar
James
Default Ceramic Spark Plug Boots??
Where can I purchase some 90 Degree ceramic spark plug boots?
I know a few guys are running them that had problems melting regular boots.
Or if anyone has a better solution.
My #3 cylinder header tube is real close so I think I'm going to need something to protect that boot for sure.
Any help would be great.
Thanks.
Old Apr 1, 2002 | 06:35 PM
zwede's Avatar
zwede
Default Re: Ceramic Spark Plug Boots?? (James)
I tried the ceramic boots, but the wire burned where it came out of the boot. I now have fiberglass boot protectors ("socks" that slide over the boots). These have worked well.
Old Apr 1, 2002 | 10:39 PM
Rob's 73's Avatar
Rob's 73
Default Re: Ceramic Spark Plug Boots?? (zwede)
Jacobs Electronics
Old Apr 2, 2002 | 09:51 AM
1LE's Avatar
1LE
Had a set of Jacobs on my 454 SS. little pricey, but worked well.
Old Apr 2, 2002 | 09:58 AM
James's Avatar
James
Default Re: Ceramic Spark Plug Boots?? (1LE)
Will the Jacobs wires work with a MSD Distributor and MSD 6AL ignition box?
I know the MSD guys want you to use a specific type of wire I do believe or they claim it can damage the ignition.
Old Apr 2, 2002 | 10:34 AM
MELVIN's Avatar
MELVIN
MSD requires you use at least an 8MM wire, I ran a MSD 6, with the accel braided, 8 mm, and no probs
Old Apr 2, 2002 | 10:37 AM
norvalwilhelm's Avatar
norvalwilhelm
I have 2 of the Jacob ceramic boots and wires and run 3 different MSD controls without problems. The Jacob ceramic boots along with the shorter Accel spark plugs solved my burned boots on 2 cylinders. The wires cost $40 CDN each but the serive was quick and they have a life time warranty.
To Ceramic Spark Plug Boots??
