Intake Manifold Gasket Help
I am not real knowledgeable about engines and was hoping you guys could help me with a few questions about intake manifold gaskets. Mine seems to be leaking oil around what I think is called the heat crossover area on the driver’s side (I have done a lot of searching on this forum, so I hope I have that term correct). I did try to tighten all the bolts, but it still is leaking. I replaced the valve cover gaskets and the leak doesn't seem to be coming from there. I posted a couple of pictures below.
1. My car has an oil consumption problem, about 1 quart every 200 miles or so. I have been keeping an eye on the area of the manifold and it doesn’t seem to be leaking that much from there. It doesn’t pool any more then what you can see in the pictures. I guess it can be leaking inside and the oil burning, is that possible? There is no blue smoke out the exhaust. Could it just be burning off from the heat of the manifold? I don’t see any smoke though. I have spray carb cleaner around the area to check for leaks and the fluid doesn’t bubble. I have pull the plugs and the ones (1, 3, 5 & 7) on the side of the leak don’t seem to bad, but the ones on the other side do seem fouled with oil.
2. If I am rolling along at low rpm’s in 1st, 2nd or 3rd and punch it, the car has a slight stumble, then will pull real nice up to 4500-5000 rpm’s (I don’t go more then this, don’t want to ruin anything). Could this manifold leak cause this? I have had the original Q-jet rebuilt by a shop I saw recommended here on the forum. I have set the timing to “all in” according to the sticky on timing.
3. I plan on replacing the intake gaskets this winter. Should I get the manifold gaskets that block the heat crossovers? I don’t drive the car that much in the cold weather. It does have the choke with the spring on the manifold. Will it just take a little longer for the choke to come off? Should I use Fel-Pro or Mr. Gasket gaskets and which part numbers? Summit lists a few Fel-Pro sets that look to only differ by port size. Is there a way to tell which I have, or do I need to wait until the manifold is off? I have read to only put a small amount of Gasgacinch around the water ports on the head side and not to use the end gaskets, just use a nice bead of sealant. I have read many posts on what gaskets to use and how and where to use sealant, but would appreciate any additional suggestions you can give.
The car is a 1971 with the 350/270hp. I believe it has (I did not install, but have receipt from a previous owner) a Compcam 270H Magnum cam. It has the original Q-jet and a stock exhaust setup.
Your stumble can be the accelerator pump shot being a little slow.
I just about always block heat from under the carb. Kind of an old school performance thing. Keep the intake as cool as I can. I rarely even worry about a choke- Ol' Red's Demon doesn't have one, and the 77's Edelbrock carb has never been hooked up.
I checked the value covers and they are not touching the manifold.
Thanks for the info that some of the bolts can "wick" oil up from below the intake too. I didn't realize this. I will try thread sealer now on that one bolt by the leak and see if it stops, and definitely use thread sealer on all the bolts when I replace the gaskets.
I will do more searches on the subject and look for the one with step by step instructions. In my earlier searches I just wasn't 100% clear on the best way to apply the sealant to the gaskets. I.E., just around the water ports on the head side only or on both sides, or on the entire gasket on the head side only, or a thin coating on both sides of the gaskets. I think I will go with the gaskets that block the heat crossovers. I like the idea of keeping the intake manifold as cool as possible.
It does look like oil and if so, it's possible that bad/burned up intake gaskets are allowing oil to be sucked into the cylinders. That will MOST CERTAINLY cause high oil consumption. I've never seen this condition look like yours but just 'cause I ain't seen it does NOT mean it isn't happening. Us engine builders have certainly seen intake gaskets cause consumption of oil though - GM had an issue with this during the '80s on factory motors. So it's not too much of a stretch to think that a rebuilder could do the same.
1) even though the carb was redone not too long ago, the ethanol in modern gasoline can cause the poly seal on the accelerator pump to swell and actually come off the piston. The engine would then act just like the accel pump in the carb was non-functional. I don't think this is the most likely problem, but wanted to make you aware of this issue.
2) the secondary [upper flap] air valve could be misadjusted so that it is getting [either] too little or too much fuel when you go to WOT. There is a little adjustment on that valve...it has a small screw on the side of the upper carb body that locks/unlocks the ability to adjust it. Then, the adjustment underneath that lock screw either tightens the spring or loosens it. That adjustment is very sensitive, so you want to barely unlock it but keep some pressure on the adj. screw so that the spring does not change its position while you are working on it. The 'base' setting for this spring is to back it off to the point that the spring just makes contact with the mechanism but there is no spring pressure applied to the valve flap. Then tighten the adj screw 1/2 turn and lock it down in place. Then try the car to see if you have a 'bog' or not. From that point, you can do more testing...in 1/4 turn increments....(keep a written record of what changes you make as it becomes confusing the more adj you make) until you find the "sweet spot" where there is no "bog" but the engine is most responsive. Either side of that point, the carb will begin to have poorer performance.
Hope that is of some help and you can get it fixed.
Thanks 7T1vette. After about 2 weeks of having the rebuilt carb on I went out one day to start the car up. The pedal went about half way down and stopped dead. I first thought the linkage was binding. Checked that and it seemed fine. Searched the forum (this forum is really great) and saw all the posts about bad accelerator pumps. Took the air horn off and found that the metal shaft had come apart from the plastic piece that has the rubber cup. Called the rebuilder and he sent me a new pump. But based on some forum posts I went ahead and ordered a pump from Cliff's Carburetors. Install Cliff's pump and no problems since. It has been about 5 months.
I have also played with the secondary spring adjustment. I have tried adjustments from 1/4 turn to a full turn, with 3/4 turn just slightly being the best. Maybe I will try a setting above a full turn.
I read some of Lars papers on Q-jets. Wow, alot of good info in these. Right now some of the stuff is just over my head, I guess I need to read them over and over again until it sinks in more. When I had the air horn off I did check the primary and secondary rods against the numbers in Lars paper. Unfortunately I didn't pull the jets out and check them. The carb is 7041213. The primary rods in the carb were 45 and Lars paper says 44. The secondary in the carb is CP and Lars paper has AR. I mentioned this to the rebulder when I called about the accel pump and he said these rods are what they use in this carb and would work fine. Actually could never talk to the main guy directly, always got his assistant when I called and he would say that he can answer all my questions. So, I just left this as is, figuring that they know better then me. And the car does pull real nice all the way up to 5000 rpm's once it gets by the stumble, so I thought maybe the problem is something else. Maybe I should look into changing the rods and jets to what Lars has in his papers.
Sorry I didn't mention this carb info in the original post, was trying to keep the post as short as possible and mainly on the intake manifold gaskets.
Good luck.
It looks like your motor is stock besides the intake manifold. The carb, distributor and exhaust manifolds all look stock. Did you notice a big difference in power with just the new intake? Did you have any problem with hood clearance? Was there anything else that you had to change because of the new intake? I am trying to keep the car stock looking, but you have me thinking now, if I have to take the old manifold off to replace the gaskets, maybe I should replace the intake.
I found a used Performer manifold at Carlisle that facilitated a choke stove and simply installed the choke stove from my stock manifold. I had to source some miscellaneous pipe plugs and assorted odds & ends to properly install the manifold. (As you can see I made up a real neat heater core shutoff valve earlier this Summer and it fits nice, looks almost stock and works great!!!) If you want to maintain a 'stock' look, simple painted your manifold with Chevy engine orange before installing it! I seriously considered shooting it in Chevy engine orange, but decided at the last minute that the aluminum manifold would look great against my new aluminum valve covers
I think a 3" open air cleaner will finish it off just right (even though the stock induction system provides cooler air at WOT through the base of the windshield ala Smokey Yunick!) It looks like your motor is stock besides the intake manifold. The carb, distributor and exhaust manifolds all look stock. Did you notice a big difference in power with just the new intake? Did you have any problem with hood clearance? Was there anything else that you had to change because of the new intake? I am trying to keep the car stock looking, but you have me thinking now, if I have to take the old manifold off to replace the gaskets, maybe I should replace the intake.
