Poly Motor Mounts Melted
Old Dec 17, 2018 | 05:52 PM
7T1vette's Avatar
7T1vette
If they were "Energy Suspension" mounts purchased over the internet, they could have been 'gypo' parts made in China made out of who-knows-what??
If you have a well balanced engine with little vibration, go with solid mounts. If you have a stock engine, install the stock rubber mounts. Either will solve your problem.
Old Dec 17, 2018 | 06:03 PM
gbvette62's Avatar
gbvette62
Originally Posted by rpoL98
on a C3, remember that the body is isolated from the frame: the body has rubber bushings for mounting to the frame. this means that vibration, noise on the frame is not transmitted into the cabin. So in the case of the C3, use of steel motor mounts does not result in a whole lot of engine noise, vibration being heard or felt in the interior of the cabin.
Only 73-82 Corvettes had rubber body mounts cushions, 68-72's used solid aluminum mounts. On 63-67's it varies by year, with 63's using solid mounts and 64-67's using a mix of solid and rubber mounts.
Old Dec 17, 2018 | 07:07 PM
rpoL98's Avatar
rpoL98
wow, I didn't know that, good to know, very interesting. I have a 78 and a 75, so both with rubber body mount cushions. I would think that the aluminum mounts would have a corrosion problem. Thanks for the correction.
Old Dec 18, 2018 | 07:26 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I have solid mounts here too. Reports of melted Energy Suspension poly engine mounts are why I bought solid ones when I already had the poly on the shelf ready to go...
Originally Posted by ignatz
You guys recommending solid mounts, are you also running a spreader bar?
Yes. But it made very little difference compared with when I was running rubber mounts, where the spreader bar made a huge difference. The solid engine mounts definitely help to stiffen the front of the chassis. I put the spreader bar in when I had the original engine and mounts in the car and it made a huge difference. I took it out when putting the new engine in with solid mounts, and drove it for a while before putting the spreader bar back in. Much less difference, almost negligible when adding the spreader bar with solid engine mounts fitted.
Old Dec 18, 2018 | 12:34 PM
ignatz's Avatar
ignatz
Originally Posted by Metalhead140
....The solid engine mounts definitely help to stiffen the front of the chassis.
Reason for me asking is that I would visualize the spreader bar helping to minimize the stresses on the main bearing next to the motor mounts. Nobody seems worried about the block becoming part of the suspension that I can tell, so it is perhaps an unfounded fear.
Old Dec 18, 2018 | 02:17 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Speaking of an engine being an integrated part of the suspension....
https://www.carscoops.com/2018/12/as...ebuts-1000-hp/
Adam
Old Dec 18, 2018 | 04:20 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by HeadsU.P.
...Some of the older fellas & gals may remember the notorious, history making GM motor mount failure of the 70's. Thousands sheared apart, usually under acceleration. The recall fix was a steel cable to harness any separation.
GM created a number of kits to deal with the issue called the Engine Lift Stop Cable Unit. You can read all about the fiasco here.
GUSTO
