68 manual trans center console
Old Oct 20, 2010 | 10:41 PM
panicman's Avatar
panicman
Default 68 manual trans center console
I have a 68 427 4 speed and I am removing the engine and trans..
How do I get the center console out?
Do I have to remove the dash cluster to get to the screws?
How do I get to the rear bolt holding down the parking brake cover?
I found this and got sidetracked for a little while.[IMG][/IMG][IMG][/IMG]
The car has been setting for 25 years and it appears some of the locals moved in.
Old Oct 21, 2010 | 10:07 AM
MelWff's Avatar
MelWff
a screw on each side and the rear bolt is accessed through the storage compartment behind the seats, I believe it is the battery compartment
Old Oct 21, 2010 | 12:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by panicman
...How do I get the center console out?...
Trim screws along the sides; two nuts on studs beneath the center cluster bezel. Trim screws on the shifter plate. Set screws on the VENT *****. Two screws on the underside of the console holding the vent door cables. I find it easier to remove the e-brake console first.
...Do I have to remove the dash cluster to get to the screws?
No. The cluster will not come out with the nuts on the studs.
...How do I get to the rear bolt holding down the parking brake cover?...
From the rear. Remove the glove box.
The assembly instruction manual (AIM) would be a big help to you. Order one. It has assembly diagrams of everything you are wanting to do.
Old Oct 21, 2010 | 03:52 PM
panicman's Avatar
panicman
I have the AIM manual but I was not to sure about everything that had to come apart.
I'm just starting on this project and I'm a little timid about takeing apart more than I have to.
Also the AIM does not tell what has to come out first.
I thank everybody on the forum for their time answering questions when I start getting nervous.
With time I'm sure I will gain more confidence.
Thanks: Matt
Old Oct 21, 2010 | 04:54 PM
BBCorv70's Avatar
BBCorv70
I've had to remove the storage compartment door frame to get the glove box out. Mine is a 70, thinks it's pretty similar.
Once the glove box is out you should be able to access a bolt which holds the E-brake console in place.
I just removed most of my interior last week...
Old Oct 21, 2010 | 05:14 PM
Alan 71's Avatar
Alan 71
Hi PM,
Here's the hole for the bolt you're looking for. You can reach it by taking the tray out of the jack compartment and reaching your hand along the rear of the seat bulkhead with a small socket wrench.
I really don't think the console needs to come out. I believe if you take the shifter **** off, the shifter will drop down when you loosen it from the transmission.
Good Luck!
Regards,
Alan
Old Oct 21, 2010 | 08:09 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
You have two boots on the shifter...the upper one is mounted to the console shifter plate and the bottom one is mounted to the transmission tunnel. If the bottom one is torn (likely) then you need to replace it if you want to keep all that BB heat out of the cabin. Although it can be done with the remainder of the console still installed, it will be a struggle. Check it out and report back.
Old Oct 21, 2010 | 09:07 PM
panicman's Avatar
panicman
Allen, I can't get to the shifter mounting bolts from under the car I think thats why I have to pull the console.
If that is not the case, can you recommend how to get to the bolts?
Faster Rat, The inner shifter boot is in good condition.
Speaking of BB heat, should I replace the insulation that fastens to the under side of the body. All that is left is a little pice behind the engine and over the trans. and that is not in good shape.
Old Oct 21, 2010 | 11:12 PM
BBCorv70's Avatar
BBCorv70
Originally Posted by Alan 71
Hi PM,
Wish I knew this last week. Would have saved me the trouble of removing the storage compartment doors and glove box..
BTW: How did you get your floor pan so clean?? No factory overspray?
I have to say I admire your pictures, never seen such a clean, well preserved car, a standard I can shoot for but may never achieve. Very nice work there!
Old Oct 22, 2010 | 09:01 AM
Faster Rat's Avatar
Faster Rat
There are no shifter bolts inside the car. Everything is underneath. First thing is to unbolt the three the shift levers from the side of the transmission. You also have to disconnect the backup light switch from the reverse lever. There are two bolts, one long and one short, that attach the shifter to the mounting bracket. They are hard to get to...I used a box end wrench and a lot of determination. After you remove the shifter, you can remove the mounting bracket.
Paragon sells the tunnel insulator and foam collar, as well as the floor pan insulation.
Old Oct 22, 2010 | 05:17 PM
Alan 71's Avatar
Alan 71
Hi BB,
I cleaned the fiberglass underbody with lacquer thinner and 3M adhesive remover.
I repainted the birdcage with an enamel matched to the original zinc paint.
A LOT of work!!! Thanks for noticing.
Regards,
Alan,
Old Oct 24, 2010 | 12:25 PM
BBCorv70's Avatar
BBCorv70
Hi BB,
Regards,
Alan,
Hi Alan,
You're quite welcome. That was some extraordinary effort you made. You well deserve recognition for your work. Very nice job,inspiring.
Old Oct 24, 2010 | 06:17 PM
panicman's Avatar
panicman
F R, thank you for the information I will be back at it monday and try to get it from underneath.
Allen, that is a beautiful job you are doing and is an inspiration to us all, thanks for all your help.
Old Oct 25, 2010 | 06:06 PM
68/70Vette's Avatar
68/70Vette
About that zinc dichromate paint. I did a Google and found a source. The stuff I bought came in a spray can and is intended as a primer for aluminum. Of course it works as a primer and protective coat for steel. It comes in two shades. One is yellowish and the other is greenish. The birdcage uses the greenish.
To 68 manual trans center console
