c3 supercharged question
Old Oct 24, 2010 | 04:25 PM
stoney500's Avatar
stoney500
Default c3 supercharged question
I am building a 355 sbc and a V1-T trim Vortech supercharger I fit under the hood (lots of mods to make it fit). Anyway, I am going with a blow through carb versus fuel injection and wondering if a 750 cfm Holley blow through carb is too much for my 355 ci engine.
Edelbrock performer rpm heads(70cc) Comp nitrous cam 8 1/2:1 forged pistons(je) 4150 crank 4150 h-beam rods. Intake is still up in the air I'm leaning toward Victor jr.
Any input would be helpful. Thanks.
Old Oct 24, 2010 | 05:21 PM
arcticcatmatt's Avatar
arcticcatmatt
Don't know what use this will be to you but my 71 has a supercharger and I just put a new holley 700 cfm blower carb on it. Doing the calculations my setup (350ci with 4-71 blower) required the 700 cfm carb.
http://www.holley.com/applications/C...bSelection.asp
http://www.holley.com/data/TechServi...Carburetor.pdf
Here is the nitty gritty manual calculator that figures in boost and all.. Look at page 7
http://www.holley.com/data/TechServi...ech%20Info.pdf
I figured mine as a 350 with a redline of 6000 rpm.. it calls for about a 600 cfm carb.. But since it is supercharged holley tech help told me to go with the 700 blower carb.
Hope that helps!
Old Oct 24, 2010 | 05:26 PM
SteveG75's Avatar
SteveG75
Edelbrock RPM heads will choke that motor. They barely work on my mild 355. Power is all about airflow. I would look into some AFR 210's for that engine. Some may say that 210's are too big but the supercharger changes all the rules.
Old Jan 16, 2011 | 08:20 PM
omegac1's Avatar
omegac1
I am putting a Vortech blow thru on my 1968 with 355. What hood did you get to fit your install?
Mike
To c3 supercharged question
