Your cam can make a difference in how much cylinder pressure you have, so I wouldn't venture a guess on the compression ratio. This link has some info that sheds some light on that- http://kb-silvolite.com/article.php?action=read&A_id=36
The good news is that your cylinder pressure is consistent in all cylinders. The closest thing I could find that relates compression ratio values to cylinder pressure (during compression testing) values was this statement from an article on the subject- A useful rule of thumb states that cylinder pressure in an engine in good condition with a mild or "street-type" cam should range (at sea level or a little above) from 17 to 20 times the specified
compression ratio.
That would ballpark your compression ratio at something between 8.0-9.4 to 1. A larger cam would obviously change those numbers.
I think some clarification is due for sanity's sake. The earlier posts were referring to dynamic compression ratio, which takes into account cam size and other characteristics, but you can calculate the static compression ratio fairly easily. The static compression ratio is simply the volume of the cylinder when the piston is all the way down divided by the volume when the piston is all the way up. Be sure to include combustion chamber and compressed head gasket thickness on both values. That's enough for a rough estimate.
Only way I know to really tell would be to cc the heads, combustion chamber, unless you already know the volume. You'd also need to know the dimensions of the piston, how the top surface is shaped. You already know the gasket thickness.. I calculated my compression ratio while heads were off. CC'd the chambers, figured out the displacement of the crown of the piston and took gasket thickness into account..
I did this a very long time ago. Don't recall all details... not sure how I figured out the displacement of the crown of the piston.. may have been given by the manufacturer?
No. You cannot [accurately] calculate the compression ratio of the engine from compression test data. {for the reasons stated above}
However, the Chevrolet Chassis Service Manualdoes have a specified range of acceptable compression test readings for the stock Corvette engines, and you can compare your numbers to that, if you wish. [Assuming that you performed the test as that manual requires.] From my 1971 CCSM, the 150-160 psi range is just what is expected for all Corvette engines (hi-perf engines @ 150; others at 160)
When doing my 427 the pistons, as made, would have resulted in something like an 11:1 comp ratio- too much with iron heads (what I had at the time) and modern gas. My builder milled the domes a bit at a time until, via ccing at TDC, we had the right chamber volume to hit a 9.5:1 comp ratio. This method, described on another forum, is what I recall watching him do-
"I use a syringe primarly used to inject medication into cattle and other farm animals. Holds 100 cc and I have plate cut from plexiglass with a hole in the top. Seal it off to the chamber with white grease and measure away."
81fixerupper,
The top link I posted described all the factors in measuring the static compression ratio.
That sounds very familiar, I recall using a piece of plexiglass and some sort of syringe to measure fluid...
Thanks guys,,,,,,I now know more that when I posted,,,,Later next month I will have the heads off and I can get it figured more accurately.
I ran a compression check and was curious as to about what it could be. I want to change my heads to a set of AFR's. The current heads are Bowtie heads ported and big valves,,,too big for my engine/cam combo.
Its always a good idea to do a leak down test as I have seen good compression tests followed by a leak down test that showed up to 40% leak down on an engine that showed 190 to 200 on compression test.
What makes you think they are too big? What are the valve sizes and port sizes in the heads?
