New fuel lines
Old Oct 31, 2010 | 05:52 PM
Johan74's Avatar
Johan74
Default New fuel lines
Should I go for steel, copper or aluminum?
What minimum inner diameter should I use for the supply and return lines?
Old Oct 31, 2010 | 08:14 PM
7T1vette's Avatar
7T1vette
Steel. 3/8", if you have a hi-performance engine; 5/16" if you don't. Aluminum and copper age and get weak/brittle.
Old Oct 31, 2010 | 08:34 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Stainless steel, and never worry about them again. Several Corvette parts suppliers sell them pre-bent to fit specific model years, so it's easy.
Old Nov 1, 2010 | 03:54 PM
Alan 71's Avatar
Alan 71
Hi J74,
Although I agree that ss lines will last longer, the steel lines are easier to bend and straighten if you're going to replace the lines with the body in place.
Just a thought!
Regards,
Alan
Old Nov 1, 2010 | 04:07 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Originally Posted by Alan 71
Hi J74,
Just a thought!
Regards,
Alan
Old Nov 1, 2010 | 04:14 PM
68/70Vette's Avatar
68/70Vette
I ordered SS fuel lines. 3/8 inch. I also ordered hem with AN fittings. This way I don't have to use rubber hose and band clamps to get fuel into and out of the lines.
Old Nov 1, 2010 | 05:48 PM
Johan74's Avatar
Johan74
What about the return line, do I need it at all?
3/8 lines for the supply are sold most anywhere, but 1/4 lines seems to be harder to find (for the return). Guess I can use 3/8 for both.
Old Nov 1, 2010 | 06:09 PM
Bob Heine's Avatar
Bob Heine
You can get a pre-bent 1/4-inch fuel return line from Inline Tube. For your '74 its a CXF7402 in original steel (SCXF7402 for stainless).
http://www.inlinetube.com/
You need the return line if you are using the stock fuel pump. It is meant to reduce percolation of the fuel, which is the usual cause of vapor lock.
Old Nov 1, 2010 | 07:33 PM
mar's Avatar
mar
SS is hard to work with and if it does not seat against the pump you are scrod. It's hard to put subtle bends in it too. Aluminum will probably seat ok. As will steel. Get a tubing bender in case you gotta' work it a little. Aluminum or steel will outlast you and your car.
To New fuel lines
