I've had no dash lights since owning the car. I'm going to have the interior torn apart while doing carpet so i want to fix/upgrade the lights while i'm there.
I have warning lights (parking BRAKE, Brights, turn signals, seat belt...)
But nothing lighting the gauges.
I'll be checking the fuse first(even though i'm sure i've checked it before)
From there I'll be checking to see if all the bulbs are just burnt out?
then either trace back power or check ground?
I have a wiring diagram so that'll help the process, just didn't know what you all suggested first that could help me out.
I'm in the same boat, had old co-worker install a "dukes of hazzard dixie horn" drove home then no dash lights, gotta check the fuse when I get around to it, been over a year, hahaa
Like yours though, my turn signal indicators, parking brake light, etc light up just not the dash or gauges..
From: San Diego - Deep Within The State of CONFUSION!
First place to look is the headlight switch. It has a rheostat around it to control the brightness of the dash. Check for an open in the rheostat. Courtesy lights are not on this circuit.
Here is where to start, one of the easiest check you have
well I'm not sure if this will work or not but the car was missing 1 fuse that said
INST LPS, The 5amp one.
I'm assuming it means Instrument something???
I broke the 10amp gauges one getting it out to check so i went and bought an assortment pack from autozone and we'll see if just adding the 5amp fixes it?
This would probably under the idiot should have checked before he asked online department...
No fuse in that spot tells me something, right there. Someone pulled it out and probably because of a known problem or because they just didn't work. My best guess was that it just kept blowing fuses, so they were afraid there was a 'dead short' which could start a fire in the dash area if current kept flowing into that circuit for too long. If you check that 5 a. fuse again, I'm betting it is already fried.
Just went out and pulled the fuse and sure enough it was blown already.
That narrows it down some but where should I start to look for this short when I get the panels off tomorrow?
From my wiring diagram it looks like the same wire comes off that fuse, splits and goes to each of the light bulbs. On the other side of the fuse it goes to the light switch...
That is correct ,
(NO reason to go towards the HL switch -drop the steering column-lower the left side dash and so on-thats a waste of time !)
you need to go the opposite direction.
In your diagram you should notice the left side of the fuse holder is the Gray wire side of the circuit. Your correct this wire splits and goes several directions to the dash illumination bulbs. Look for a pinched gray wire. One very common thing you'll find on these old cars is the socket falls apart and the gray wire then comes in contact with the metal housing.
I start off with the easiest , looking up from the bottom of the dash,
then I remove the right side of the dash and look in behind the center cluster and so on until you find the short.
I believe back in the day they used to locate shorts with the good ole paper clip method, ummmm...... I would stick with Rogers advice 1st though ! Good luck, dont ya just love those electrical gremlins.
Remove the positive battery lead. Then use an ohmeter to test the output side of the fuse clips to see if you have a dead short to ground. Repeat the process for the fuse clip on the other side [fuse out of the clips, of course]. One side or the other should show a short condition (zero ohms).
Note: I would expect to see low ohms on the output side, as you could be checking continuity through a light bulb, etc. That would get you into the range of a few ohms. But your problem is [essentially] a 'dead' short and that's what you need to look for. Short both meter leads to ground and see where the meter needle (or reading) ends up...that's what you should see when you find your problem.
Once you find the short, you need to move 'away' from the fuse but in that electrical 'line' until you find that the short condition disappears. The short will then be located somewhere between the side of the fuse showing the short condition and the point at which the short disappears. You just need to continue to narrow the search area in that 'bad' section until you isolate the short. Good luck.
Well I got the center console and gauge cluster out today along with all the carpet.
Next free day I have I'll most likely tackle the the steering column and speedo/tach dash pad to open up all that area.
This should allow me view of the entire area that is having a problem. From what I could see in the console and gauge cluster area the lighting looked pretty good at all points. So i'm guessing my problem lies somewhere over in the tach/speedo area.
The instrument lamps have to be grounded or they will not work. They ground by clipping into the rears of the metal cased instruments and by the harness ground on the driver's door hinge post up under the console.
If you keep blowing IP fuses, I'm betting the headlight switch has a bad rheostat.
