supply line
Old Nov 10, 2010 | 10:27 PM
LT-1 kid's Avatar
LT-1 kid
Default supply line
what line is the supply to the heater core for a cut off switch to reduce the heat in the car for summer time, 5/8 or 3/4, thanks. 69- 350
Old Nov 11, 2010 | 12:57 AM
Peterbuilt's Avatar
Peterbuilt
The 5/8 line.
Old Nov 11, 2010 | 10:32 AM
Mike Ward's Avatar
Mike Ward
It doesn't matter which line has the valve in it, stopped is stopped.
Old Nov 11, 2010 | 11:05 AM
7T1vette's Avatar
7T1vette
Mike is correct. A manual valve in either line will stop water flow...which is what the heater core needs for generating heat. Select the line that best suits your needs for where you want the valve.
Old Nov 11, 2010 | 11:21 AM
Peterbuilt's Avatar
Peterbuilt
The stock shut off valve is 5/8.
Old Nov 11, 2010 | 08:22 PM
LT-1 kid's Avatar
LT-1 kid
thanks for the response, I will use the 5/8 line.
To supply line
