strange electrical part
Old Nov 14, 2010 | 08:42 PM
jmo4x5x's Avatar
jmo4x5x
5th Gear
Default strange electrical part
just joined and working on first 1972 corvette repair, repairing wiring in dash be a mechanic over 25 years and would like to shoot the butchers who worked on this nice car. cut and spliced wiring all over the place. ok i vented. i have found behind pass. side dash a silver part thats pluged in wiring spliced into factory wiring of light sockets, pink and black wires (2) it looks like a old style starter for flourescent (sp) lights it has spade ends for the wires, i have a 1971 car not butchered it is not a factory install on this car, this car is a one owner. 1972 do not know history. i have books and wiring diagrams not found. thanks if anyone knows what this is, not looking like the seat belt warning buzzer
Old Nov 14, 2010 | 08:55 PM
oldsarge's Avatar
oldsarge
First welcome to the forum. Can you post a pic it makes things alot easier to identify?
Old Nov 14, 2010 | 09:09 PM
DC3's Avatar
DC3
Turn signal flasher? Don't know about the other year models but the turn signal flasher on my '73 is found behind the passenger dash (the hazard flasher is plugged into the fuse block).
DC
Old Nov 14, 2010 | 09:36 PM
jmo4x5x's Avatar
jmo4x5x
5th Gear
i will post picture monday, it not the turn signal flasher that is mounted in clip on back of dash ,they had mounted this thing on the firewall.
Old Nov 14, 2010 | 10:40 PM
7T1vette's Avatar
7T1vette
If this is a cannister mounted to the brake pedal linkage and is connected via some blue splice connectors, it is a radio noise suppressor (filter) capacitor and it DID come from the factory that way. Chances are the capacitor has long since "bit the dust", but it does no harm in the circuit. (It may do no 'good' if it is kaput, though.)
If you get no static (EMF ignition spikes) noise in your radio, don't worry about it.
Old Nov 15, 2010 | 09:26 PM
jmo4x5x's Avatar
jmo4x5x
5th Gear
tired to add picture no luck, found numbers on unit, Sylvania 03961500 ,i also googled no luck
Old Nov 15, 2010 | 09:34 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
That part is a time-delay relay for the seat belt warning light, and it was factory on early '72s, they went to a contact in the seat belt retractor on later '72s. My 72 is number 456, and I had it in my car.
When the ignition was turned on, the relay contacts closed and the warning light was lit for a brief period of time, and then the contacts would open and the light would go out. It would happen every time regardless if the seat belts were done or not.
Old Nov 16, 2010 | 08:30 AM
jmo4x5x's Avatar
jmo4x5x
5th Gear
thanks all the info showed different shape unit a flat warning buzzer, plus this unit was spliced in and wrapped with tape like it was added later. then again i have found wiring cut and taped for no reason, this is a great source of info after reading a lot of the post.
To strange electrical part
