Why vacuum canister
Lars
The thing is,,
I can make the lights work when hooked direct, will not work when hooked to the tank. The tank does build a vacuum , just will not operate the lights. Very weird. More beer and pontification tonight!!
The thing is,,
When your headlight switch is in the "off" position, vacuum is routed from the intake manifold, through the filter and the check valve, through the headlight switch, through the backup "pulldown" switch below the steering column, and to the tops of the headlight relays. Vacuum pulls the valve in each relay upward and vacuum is routed from the tank to the rear side of each headlight actuator. Thus vacuum holds each headlight down (retracted) when your headlights are "off".
When your headlight switch is in the "on" position, manifold vacuum is blocked at the headlight switch and atmospheric pressure enters there, proceeds through the "pulldown" switch, and to the tops of the headlight relays. Without the vacuum, the valve in each relay is pushed downward by a spring and vacuum is routed from the tank to the front side of each headlight actuator. Thus vacuum holds each headlight up (extended) when your headlights are "on".
If you really do want to bypass the vacuum tank, remove all 3 hoses (1 unmarked and 2 with yellow stripes) from the vacuum tank. Take the unmarked hose that comes directly from the check valve (near the intake manifold), and connect it (using a "T") to the 2 yellow-striped hoses that connect to the middle ports of each relay.
I have a solid 18 vacuum on the lines.
When the passenger headlight comes up (it raises quickly and strong) it empties the vacuum tank in the frame.
It then takes about 8 seconds for the vacuum to build back up to 18 in the tank, and then the driver side headlight pops up as expected.
1. Why does the passenger headlight empty the tank?
(I, too.... am pondering a bypass of the tank.)
Rather than the passenger headlight emptying the tank, it's more likely the driver's side headlight vacuum circuit is doing it.
Suggest you first check the driver's side actuator using this procedure:
http://www.corvette-101.com/vacuum.htm#actuator
I like to run this procedure by disconnecting the red and green striped hoses from the relay and connecting the vacuum pump to those hoses. That way you check the actuator and the hoses.
If the actuator passes that check, then test the relay using this procedure:
http://www.corvette-101.com/vacuum.htm#relay
Remember to test the yellow-striped hose connecting the vacuum tank to the relay.
The the relay test in the above link includes a link to a "Headlight Relay Repair" procedure that you may want to consider. Here's a link to another relay repair that worked well for me:
http://forums.corvetteforum.com/c3-t...ay-valves.html
Good luck!
Jerry
