70 dash pad in a 69?
Old Nov 18, 2010 | 08:50 AM
mysixtynine's Avatar
mysixtynine
Default 70 dash pad in a 69?
Anyone ever put a 70 dash pad in a 69?
Thought it would be nice to have the speakers up high instead of at your feet. Just don't know if any provisions where made to the birdcage for speaker clearance or if the rest of the interior windshield moldings would have to be changed as well.
Putting speaker in the back with a convertable doesnt seem like its gona work much better.
Old Nov 18, 2010 | 08:57 AM
76yellow's Avatar
76yellow
I don't see where there would be a problem !
Old Nov 18, 2010 | 09:29 AM
bashcraft's Avatar
bashcraft
I have a '71 dash pad in my '69. No problems at all.
Old Nov 18, 2010 | 09:41 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It will fit just fine.
Old Nov 18, 2010 | 10:59 AM
mysixtynine
Great news. Thanks guys.
Those of you that have done it, did you do it for the same reasons?
Old Nov 18, 2010 | 11:07 AM
bashcraft's Avatar
bashcraft
I did it because my original was shot and I found a good one from a wrecked '71.
Old Nov 18, 2010 | 11:35 AM
mysixtynine
As I am unfamiliar with how the speakers mount, are there bosses built into the dash pad that you screw the speakers into or do the speakers have some type of mount thats needed?
Old Nov 18, 2010 | 11:37 AM
bashcraft's Avatar
bashcraft
It's been awhile, but I'm pretty sure that there's bosses.
Old Nov 18, 2010 | 04:12 PM
Alan 71's Avatar
Alan 71
Hi msn,
The 71 speakers have a housing that screws to the dash pad. The housing has threaded studs that the speaker attaches to with small nuts.
Regards,
Alan
Old Nov 18, 2010 | 06:33 PM
7T1vette's Avatar
7T1vette
Alan is correct. The 70 & up dash pads have speaker 'holders' in which the speakers mount...then those are attached to the bottom of the dash. If you get the '70 dash, you need the speaker 'holders' also...otherwise a good pothole will cause the speaker to drop out of the dash pad.
I went the other way with my system. I have a '71 and added kickpanel speakers to the original AM-FM/stereo radio. I replaced the dash speakers and added some in the kicks; all speakers were readily available 4 ohm units and the two speakers on each side were wired in "series" so that the impedence on each side is 8 ohms...very close to the 10 ohm amp output of the Delco unit. Sound is much more robust with good highs from the dash speakers and good mid freq [and decent bass] from the kickpanel speakers. Much better system than the original design (either the 68-69 or the 70-76 vehicles).
Old Nov 19, 2010 | 08:21 AM
mysixtynine
Thanks guys, this has been real informative.
Anyone know where to get the speaker holders or what they look like?
Nevermind... found some on ebay. Thanks again guys.
To 70 dash pad in a 69?
