transmission shift
Old Nov 24, 2010 | 05:43 AM
glo's Avatar
glo
Default transmission shift
I have a 77 corvette with a automatic th350transmission .Trans has been rebulit with a shift kit added and a 2500 stall convertor.My ? is is how many times should it shift.
From a dead stop it shifts 2 times once at about 15mph and again at 25mph not sure at mph due to speedo may be not correct. Also I can not get my passing gear to work. I did the adjusting on cable with throttle wide open and pull tv cable out all the way out and connected it.The motor is is 383 with holley 750 vac.The transmission shifts great no slipping .
Gary
Old Nov 24, 2010 | 07:49 AM
gcz49's Avatar
gcz49
Trans is a 3 speed, will shift twice. Try adjusting the cable by holding carb at wot only and then push down on lock. No need to pull cable all the way out.
Old Nov 24, 2010 | 12:37 PM
TimAT's Avatar
TimAT
2 shifts- 1-2 at about 15-20, then 2-3 about 25-30. Rough guess, shifts depend on road speed and engine vacuum. Adjust the detent cable (for a start), so that it starts to pull on the cable about 1/2 throttle. As the throttle opens, the cable moves the detent shift valve and forces the 3-2 downshift.
Old Nov 24, 2010 | 12:57 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
If it's upshifting at 15mph, it is acting like the detent cable has absolutely no pressure on it at all. Is it drooping at the carb?
Old Nov 24, 2010 | 04:21 PM
glo's Avatar
glo
I will try adjusting cable .No cable is not drooping as a matter of fact
it seem to downshift harder when cable droop not sure thats the right word use. Felt downshift more.
To transmission shift
