Pulling out of storage!
Old Nov 29, 2010 | 09:49 AM
bikertim's Avatar
bikertim
Default Pulling out of storage!
I am new to corvettes, and just purchased my first C-3 corvette. It has been driven very little in the last 5 years (the owner says 300 miles) but has been stored in a garage under cover. The car runs and drives fine so I am not too concerned, but what should I do prior to driving it somewhat reguarly? The oil and filter have been changed annually. I know to look real closely at the belts, hoses, brakes, tires and such but are there any items I should look at closer being a corvette?
I plan on drviing it 5000-6000 miles a year.
Thanks in advance for any advice!
Old Nov 29, 2010 | 11:21 AM
wnmech's Avatar
wnmech
Welcome to the forum. What you listed to me looks like you should have everything covered. You might want to also replace the coolant and fuel filter
Old Nov 29, 2010 | 01:46 PM
Dodosmike's Avatar
Dodosmike
Rear end fluid
Grease anything that "pivots", suspension points etc.
check to see that the heater core isnt plugged with any "goo", Remove the hoses and flush out with gentle garden hose pressure.
make sure the wipers work, "just in case".
rinse out the rad as well, dont forget the AC rad if so equipped.
dodosmike
Old Nov 29, 2010 | 02:20 PM
Alan 71's Avatar
Alan 71
Hi Tim,
CORVETTE NICE!!!!!
There's been a lot of talk about tires that look great because they've had little use but are past their "expiration date". The tire manufacturers state that the tires age from the environment and become dangerous to drive on.
If you do a search on this Forum and the web I think you'll find the info.
GOOD LUCK!
Regards,
Alan
Old Nov 29, 2010 | 02:21 PM
69small block's Avatar
69small block
please ck tires age does matter on those things some day 5 some say 8 years if any doubts put new ones on regardless of tread on tire an ezploding tire can make a mess out of fibrglass
Old Dec 1, 2010 | 12:36 AM
LT1driver's Avatar
LT1driver
manufacturers say 6 years, I would replace if that old for sure unless all you did was move in/out garage or trailer but since you plan to drive it, new tires a must if over 6 years, all fluids no matter when last done...do it right and start at a point "you" know to be right and enjoy, enjoy, enjoy
Old Dec 1, 2010 | 01:39 AM
terry82's Avatar
terry82
check front and rear bearings .take a look at the rear strut rod busings.and check all lights.
Old Dec 1, 2010 | 12:03 PM
bikertim's Avatar
bikertim
Default Thanks!
Thanks for all the responses. The tires were just replaced as well as the rear calipers. The PO started the car once a month with the heater on to circulate the fluid through the heater core.
I think i will take the flushing of radiator and all fluid changes/chassis lube advice before driving it much. I bought it to tinker with as well as drive, so this is as good a place as any to start.
Once I get the car home I will take some photos and post -- its a 1973white with black interior -- 350 4 speed coupe.
Thanks again!
Old Dec 1, 2010 | 09:50 PM
tnovot's Avatar
tnovot
Thanks again!
It's good the hear that you like to "tinker". There is always something on these older cars to repair or upgrade. You should be thankful that the previous owner gave the car some attention while the car was in storage. Good luck with the new ride.
Terry
To Pulling out of storage!
