Vapor Canister Question
Old Nov 30, 2010 | 04:42 PM
Bally's Avatar
Bally
2016 C3 of Year Finalist
Default Vapor Canister Question
Hi,
The charcoal in the vapor canister of my '71 LS5 has pretty much turned to dust, and is no longer effective after 39 years.
Companies listing replacement canisters all seem to be showing 'discontinued' for this specific canister.
So, I'd like to reuse my original one, which is otherwise in good condition.
My Question: Does anyone know of how to obtain correct replacement charcoal for this application?
I know the bottom filters are available at most any auto parts store, but I don't see charcoal available anywhere.
If I can reuse the canister I have, that'd be great.
Thanks a lot for any suggestions and/or advice!
Bally
Old Nov 30, 2010 | 05:05 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
I think the standard "rebuild" procedure is to cut it open, and buy some activated charcoal at pet stores (I think that is where it is sold, although it does sound strange!). IIRC, some people cut the bottom of the can open, then refill it and epoxy it closed again. Or you could get another vapor canister from a junkyard.
Will
Old Nov 30, 2010 | 05:49 PM
Alan 71's Avatar
Alan 71
Hi Bally,
I think Will's right on. I believe people use the charcoal that folks with fish tanks use in their filters.
IF you cut yours open I'd LOVE to see some pictures.
Regards,
Alan
Old Dec 1, 2010 | 12:40 PM
Bally's Avatar
Bally
Thanks guys,
If anyone else would care to weigh in, I'd sure be interested.
I mentioned to the fellow rebuilding my engine (he is a stickler for originality, which I appreciate) about using activated charcoal from a pet store in the canister, and he was less than enthusiastic about that idea!
I've heard of others doing that though, and there seems to be no problem.
Odd that one can't buy automotive grade replacement charcoal for the canister. Maybe replacing the entire canister use to be easy and cheap; now you can't easily find one, at least for an August 1970 built '71 Vette.
Old Dec 1, 2010 | 02:20 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by Alan 71
Hi Bally,
Regards,
Alan
Old Dec 1, 2010 | 02:57 PM
7T1vette's Avatar
7T1vette
If yours no longer is functional, you have little to lose by trying to recharge it. If nothing else, it would be good information for the rest of us...as to whether that alternative is viable or not. Keep us informed if you try it. {I would, if I needed to do it.}
Old Dec 1, 2010 | 05:23 PM
Will's'74VetteL-82
Yeah you could give it a shot, unless you dont want to cut the old one open, and I think all activated charcoal is the same.
Will
Old Dec 1, 2010 | 05:48 PM
Bally's Avatar
Bally
I might try it then.
My concern is that the aquarium charcoal would be of a different, lighter weight and that it might get sucked through into the carb or some other quite undesirable scenario!
That's why i wondered if anyone here had used it successfully...
Thx!
Old Dec 1, 2010 | 06:15 PM
Will's'74VetteL-82
Thx!
Oh I understand, I didnt think of that, try comparing the new activated charcoal to the stuff that's in there. Maybe try to find a heavy type activated charcoal.
Will
Old Dec 1, 2010 | 09:01 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Thx!
I do not think that canister would send anything up to the carb. I know the fuel tank runs to it, but not sure if there are any carb lines to it.
Old Dec 1, 2010 | 11:11 PM
7T1vette's Avatar
7T1vette
I don't know how the cannister is constructed, but I would think there is some sort of 'screen' to prevent any of the charcoal media from being injested by the engine. There are two lines from the carb connected to the cannister: one that supplies a vacuum 'signal' and the other that joins with the PCV valve output before going into the base of the carb. The only thing that should ever get sent to the carb [from the cannister] is fuel vapors.
To Vapor Canister Question
