Slide seal
Old Dec 1, 2010 | 04:59 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Slide seal
Is there a trick to installing the slide seal on the emergency brake handle & hooking up power window switches on the console on a '73?
Thanx for any help !
Old Dec 1, 2010 | 11:18 PM
7T1vette's Avatar
7T1vette
Well, if it doesn't have a small 'slice' through the left side, centered and adjacent to the slot for the lever, you had better put one there. Otherwise, it will be really hard to assemble it.
Old Dec 1, 2010 | 11:57 PM
keeks2915's Avatar
keeks2915
the replacement slide seals can be brittle if the channel isn't allowing it to slide freely.
I would buy 2- 3 as they are pretty cheap AND warm them up in hot water so they can be moved around.
GENTLY test the parking brake handle Slowly to make sure it isn't binding, especially as you release the brake handle. They sometimes get stuck under the shifter console and then you are taking the whole thing apart again.
Old Dec 2, 2010 | 12:08 PM
TERRY CLARK
Pretty sure they all have a slice !
Old Dec 2, 2010 | 01:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Slider and switches will only install one way. PW harness simply plugs into the base of the switches.
It helps to have the e-brake console out for both.
Old Dec 2, 2010 | 06:01 PM
Alan 71's Avatar
Alan 71
Hi,
I believe that if the slice is done with a very sharp blade and done in the "low" part of the ribbed pattern, the cut really can't be seen once the slide is back in the track.
Good Luck!
Regards,
Alan
To Slide seal
