Water Pump Pulley
Old Dec 5, 2010 | 06:03 PM
vietvette 77's Avatar
vietvette 77
Default Water Pump Pulley
I want to put a chrome water pump pulley on my 77 L 48 350. One source says I have a long water pump, one says I have a short. One says it's determined by which side the alternater is on. Still another says the hole size varies. Can anyone help me? My alternator is on the driver side.
Vietvette
Old Dec 5, 2010 | 09:07 PM
TPI BOY's Avatar
TPI BOY
Why not get yours chromed Corvettes
have a special size not long not short
Old Dec 5, 2010 | 10:08 PM
wcsinx's Avatar
wcsinx
Who told you that?
It's the short one. I just ordered this one from Summit ... fit like a glove. http://www.summitracing.com/parts/AAZ-58-148/
Old Dec 5, 2010 | 10:19 PM
noonie's Avatar
noonie
Originally Posted by wcsinx
Who told you that?
TPI BOY is correct,
You got the Corvette only pump, check the "Check Application" link on the link you posted.
It does have an error though, the Corvette pump fits from 1971-82 sbc vette not 75 to 79 and is Block to hub----5.795"----3/4" shaft,
whereas the regular short pump is Block to hub----5.625"----5/8" Shaft
Old Dec 5, 2010 | 10:33 PM
chonkyapple's Avatar
chonkyapple
I bought a new pump for my 78 thinking sb chevs were all the same,wrong,
The pulley hit the pump housing and as noonie said it had a 5/8" shaft
instead of 3/4"
Old Dec 5, 2010 | 10:59 PM
wcsinx's Avatar
wcsinx
Originally Posted by noonie
TPI BOY is correct,
Interesting, all I saw was ...
"Water Pump, Remanufactured, Replacement, Chevy, Small Block, Short, Each"
Never knew Corvettes had specific water pumps. I stand corrected.
Old Dec 6, 2010 | 08:53 AM
pippo350's Avatar
pippo350
You can think about this:
http://www.summitracing.com/search/P...uff+water+pump
To Water Pump Pulley
