1972 SB temperature sending unit
Old Dec 5, 2010 | 07:20 PM
makosilver72's Avatar
makosilver72
Default 1972 SB temperature sending unit
My temperature gauge on my '72 SB reads very cool temp - basically barely moves. Where is the temperature sending unit on my engine located? I thought it was on the drivers side around the spark plugs.
Also, do I need to remove the drivers lower dash pad to run the the wires/lines for the new sending unit?
Thanks for all the help.
Old Dec 5, 2010 | 08:44 PM
ED DINAPOLI's Avatar
ED DINAPOLI
The temp sending unit for you gauge is above the number 1 spark plug. I would check your termostat for proper operation before fooling with the wires and sending units. Did the combination of sending unit and gauge work properly before or is this a new set up.
Ed
Old Dec 6, 2010 | 05:27 PM
Alan 71's Avatar
Alan 71
Hi ms72,
If you determine the problem is with the sending unit there won't need to any change in the wiring. The temp wire is part of the engine harness and plugs into the sending unit on the engine and is connected at the rear of the gauge in the cluster. You'll just need to change the sender.
Regards,
Alan
Old Dec 6, 2010 | 05:30 PM
makosilver72
The temperature gauge and sending unit did work about three months ago - last time car was run for any time and it seemed to run cool but within range. Now, the last afternoon out, the gauge never really moved much above 100 degrees. I have replaced bulbs and clock in the center console. Is it possible to have loosened something on the back of the gauge?
Old Dec 7, 2010 | 10:07 AM
lavery48's Avatar
lavery48
I wish mine ran that cool....I'm in Texas and I have heating problems with all 3 of my mine.
Old Dec 7, 2010 | 02:41 PM
rugerm44's Avatar
rugerm44
Makes sure your thermostat isnt stuck open.May want to replace it first if you havent already.
Old Dec 7, 2010 | 03:39 PM
Peterbuilt's Avatar
Peterbuilt
You might want to make sure the gauge works first, to test:
With the key "ON" remove the wire from the sending unit-gauge should go to "COLD".
Now ground the wire-the gauge should now go to "HOT".
If it does the above then the gauge is good and the sender is bad or your thermostat is stuck open.
Old Dec 7, 2010 | 06:54 PM
72LS1Vette's Avatar
72LS1Vette
If you do a search you will find lots of threads about temp sensors. A forum member (Roger) did some comparison testing fairly recently and this sensor, available at Advance Auto was one of the most accurate:
WT203Z
The nice thing is it only costs $7.00 so if that turns out not to be your problem you're not out a lot of $. The tip is different than the blade connector on my 72 but you can just turn the connector sideways and slip it on.
Rick B.
To 1972 SB temperature sending unit
