Hissing under the dash
Old Dec 5, 2010 | 07:42 PM
dgood's Avatar
dgood
Default Hissing under the dash
Well I finally got my car running and noticed a hiss under my dash. It is coming from the area around my light switch and bypass valve. The lights do not come up. The vacuum and lights worked fine before I was working on my car and I didn't do anything in the interior. What is the best way to determine if the switch or bypass valve is bad. I checked all the hoses and the are connected.
Dan
Old Dec 5, 2010 | 07:46 PM
Duane4238's Avatar
Duane4238
Sounds like you may have jarred a hose connection loose or one has split. On the other hand, do you have any large snakes in your area of the country?
Old Dec 5, 2010 | 07:48 PM
dgood's Avatar
dgood
I will check again for a loose hose. No snakes but we had a hell of a snow storm here in Virginia last night, almost a 1/10 of an inch. WOW!
Old Dec 5, 2010 | 07:50 PM
Duane4238's Avatar
Duane4238
Sorry, I couldn't resist. Just take a length of hose and put it to your ear. Start the car and move the other end of the hose around under the dash until you pinpoint where the hissing is coming from.
Old Dec 5, 2010 | 07:52 PM
Duane4238's Avatar
Duane4238
Sounds like quite a storm. My Vette is put away for the winter months. Tonight we're supposed to get from 6-12" of new snow.
Duane
Old Dec 5, 2010 | 08:38 PM
dgood's Avatar
dgood
I am from michigan but moved here about 20 years ago, no desire to go back to the snow and cold.
Old Dec 5, 2010 | 09:27 PM
C3Dave's Avatar
C3Dave
I bet your vacuum hoses on the back of the head light switch are reversed. Try switching them and see if that fixes it. I know from it happening to me.
Old Dec 5, 2010 | 09:59 PM
7T1vette's Avatar
7T1vette
Vacuum hose or fitting problem on the bypass valves, most likely. Remove the lower steering wheel cover, then remove two sheet metal screws which mount the bypass valve plate to the underside of the dash. You should be able to see what the problem is at that time (if it is on the bypass plate). Other possibilities are: the wiper solenoid/switch mounted to the backside of the tachometer gauge and the headlight switch. [...hope it isn't the latter item...]
Old Dec 6, 2010 | 12:15 AM
Vette5.5's Avatar
Vette5.5
Probably a good idea to get a Mity-Vac test kit for all the under dash vacuum operated stuff in these car's. Better still, a motorized vacuum pump from an HVAC service guy. A lot better than having to run the engine.
Old Dec 6, 2010 | 05:42 AM
dgood's Avatar
dgood
I will pull the bypass valve today. C3 Dave, I don't think the hoses got switched. I haven't drive the car in a couple of months and everything worked fine. I am wondering if I maybe swapped some hoses down by the headlights when I had the lights and radiator support out. Damn.
Old Dec 6, 2010 | 06:21 AM
7T1vette's Avatar
7T1vette
That wouldn't cause any 'hissing' under the dash. You have a line loose under there...or a broken fitting.
Old Dec 6, 2010 | 05:51 PM
dgood's Avatar
dgood
7T1vette, I think you are right. Got underthere today and the headlight switch and bypass valve are not leaking/hissing. Something else is. I guess I will pull part of the dash and see what it is. It is not the vents and I disconnected the brake booster and that was not causing it. I am maybe thinking something with the heater/ac controls. More later.
Old Dec 6, 2010 | 05:58 PM
...Roger...'s Avatar
...Roger...
Before tearing into the dash check under the hood real good. I have had a leak under the hood cause a sound of hissing under the dash. Probably the vacuum going through a restriction. Get a pair of pliers and start pinching hoses under hood and have someone listen inside for the hiss to go away. I can't remember exactly what the leak was but it sure fooled me,but it only fooled me once !
Old Dec 6, 2010 | 06:23 PM
Duane4238's Avatar
Duane4238
Like I said at the beginning of your post, just take a 4' length of small diameter rubber hose, stick one end in your "ear" (that's with one r not two) and then move the hose around under the dash, and under the hood, as Roger suggested! Don't start taking things apart and making extra work for yourself(and the chance to screw something else up) until you've pinpointed where the hiss is coming from. If you'd have done this first, you'd have it fixed by now. Good luck! And, we did get dumped on today. I snowblowed the driveway twice today and it's still coming down.
Old Dec 6, 2010 | 07:33 PM
7T1vette's Avatar
7T1vette
Vacuum does operate the heater/a/c servos/doors in the interior. There is a vacuum distribution manifold attached to the left side of the heater control [in the lower console]. With the engine running, move the left thumbwheel through all the possible settings and listen for the 'hissing' to change in sound. If it does, that indicates that you have a vacuum leak problem in that system and not under the driver's side dash area. Noting the thumbwheel setting(s) where the vacuum leak disappears will provide clues as to where to look in that system for the leak.
Old Dec 6, 2010 | 07:47 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I had a hissing under my dash, so I hooked up a long hose to a secondary vacuum source (my wife's car) and zeroed in on it. Turns out it is the vacuum actuator on the driver's end of the heater box. When I reach up and press on it, the hissing stops. Evidently those actuators (there are 2 - one also on top of the box) have a shaft seal that hardens over time. Next time I rip the dash apart I plan on replacing it. This actuator controls the defroster flap...not necessary in Miami. Meanwhile I just disconnected the vacuum line for the interior heater controls where it tees inside the engine compartment and plugged off the source.
Old Dec 7, 2010 | 09:47 AM
dgood's Avatar
dgood
found the hose. It was inside the engine compartment. It was one of the hoses that comes from the cruise control. blocked it off for now until i find out where it goes. Forgot that I had replaced the cruise control last month and must have left a hose off. Thanks all. Glad I did not have to start pulling dash parts
To Hissing under the dash
