Hardened Push Rods?
Old Dec 15, 2010 | 11:43 AM
trainor's Avatar
trainor
Default Hardened Push Rods?
I'm about to put some IK180 Brodix heads on my 1975 L-48. Before I do the teardown I was wondering if anyone knows if the stock push rods in this motor from the factory are hardened. The reason I want to know cause if it doesn't I need to order a set pryor as we haven't any shops here that stock them. I spoke with an engine builder and he said there is a good chance they are hardened. Anybody with input is appreciated. Thanks
Old Dec 15, 2010 | 11:53 AM
7T1vette's Avatar
7T1vette
"Hardening" is a relative issue. What you need is strength and wear resistance. When spending big buck$ on an engine, better [than stock] pushrods is necessary.
Old Dec 15, 2010 | 12:10 PM
jordan89's Avatar
jordan89
Old Dec 15, 2010 | 12:38 PM
DO2G's Avatar
DO2G
I just bought the same heads. What length push rods are you going with?
Old Dec 15, 2010 | 01:06 PM
trainor's Avatar
trainor
I was told to go with the stock length just make sure the are hardened. What HP are you expecting to gain. I was told with the cam and all I have to expect 50hp gain.
Old Dec 15, 2010 | 01:15 PM
rbrock's Avatar
rbrock
Unless the heads form the L48 had guide plates and screw in studs then it wouldn't have had hardened push rods.
Old Dec 15, 2010 | 02:19 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
My AFR 195's came with docs that recommended Chromoly pushrods. I think it cost me only like 75 bux for the set or so.
Old Dec 15, 2010 | 02:20 PM
bashcraft's Avatar
bashcraft
Hardened pushrods are for use with guide plates. Do your new heads have guide plates?
Old Dec 15, 2010 | 02:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you use guide plates you must use hardened pushrods. I use the .080" wall Comp Pro Magnum pushrods in mine
Old Dec 15, 2010 | 03:19 PM
midyearvette's Avatar
midyearvette
check your rocker arm geometry first, then order a hardened set, there is a good chance your stockers are the wrong length, you won't know until you check.....good luck.....
Old Dec 15, 2010 | 03:48 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Funny opinions everywhere, stock pushrods are harden, don't think so? try cutting one! Anyway the right answer is that you need to check everything and be sure of the length you need, no one can tell you for sure what you need till you check them! You should have the contact of the rocker in the middle of the valve tip at 50% lift. Chrome Moly rods are a good choice because they are soft but have good memory and don't bend easy. Being soft is why they do not break as easy and they give and spring back, not the best for HP but then they don't break very easy either.
Old Dec 16, 2010 | 08:03 AM
DO2G's Avatar
DO2G
Yes on the HP and use Hardened Push Rods. Brodix told me to check for the accurate length.
To Hardened Push Rods?
