'76 window switch orientation
Old Dec 15, 2010 | 07:55 PM
dragos818's Avatar
dragos818
1st Gear
Default '76 window switch orientation
Forgot to mark the window switches when I took them out of the console; (doing a restoration) Don't know which way they go back in; (can't tell by the wiring, that has been moved around). Could use a little help! Thanks
Old Dec 15, 2010 | 08:02 PM
randyredleg's Avatar
randyredleg
Forward is up, pull back for down. You can plug in the wire and test before you bolt it in.
Old Dec 15, 2010 | 10:15 PM
7T1vette's Avatar
7T1vette
Hmmm. I think mine work the reverse of that: forward for 'down', back for 'up'.
In any case, the wiring is pretty stiff and the sockets have a non-symetrical contact pattern. So, I think you can only assemble them [easily] in one way for the pins to fit without twisting up the wiring.
Old Dec 15, 2010 | 11:32 PM
U17's Avatar
U17
Mine are "down" for down and "up" for up ....
Old Dec 17, 2010 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by U17
...Mine are "down" for down and "up" for up ....
I agree.
The switches are the same - no left or right. The connectors on the PW wiring harness ARE left and right.
The AIM diagram helps a little. Plug a switch up and test it. Mark the harness for left and right.
Old Dec 17, 2010 | 05:29 PM
1yy07's Avatar
1yy07
Default window swich
look at the aim there is a little detent were the screw goes in looks like half of the ear is broken off
To '76 window switch orientation
