What are these hooks for???
Old Dec 19, 2010 | 09:03 PM
samuk's Avatar
samuk
Default What are these hooks for???
Under the passenger and driver floor. Outside.
Old Dec 19, 2010 | 09:16 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
If I'm not mistaken I believe those metal tabs are there to hold the heat sheilds that protect the engine compartment side of the floorboards. Those shields are absent on my buddies '68 427 400 h.p. and man do your feet get hot!
Old Dec 20, 2010 | 01:06 AM
sly vette's Avatar
sly vette
Correct!Heat shield mounts!
Old Dec 20, 2010 | 07:11 AM
samuk's Avatar
samuk
Anyone got a picture of that???
Old Dec 20, 2010 | 07:35 AM
avner's Avatar
avner
There are few depend on year, AC....
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Avner
Old Dec 20, 2010 | 07:47 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Here is a picture of my '69. The pointed tabs are riveted to the floor boards in many locations, including the tunnel, to hold the foil covered insulation in place. The flat tabs on the cross member and floor are used to mount the metal shields and white plastic toe boards in the lower firewall area.
Old Dec 20, 2010 | 08:19 AM
samuk's Avatar
samuk
so there is a upper part and a lower part.
Old Dec 20, 2010 | 12:12 PM
mudbone64's Avatar
mudbone64
Apparently there is a upper and lower for '68s & '69s
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
If you'll notice the next link is for a "late" '69.
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
This link is for an "early" '69.
Late '69 w/AC:
You might to research these for yourself as I could have made some mistakes. I hadn't ever seen any "underbody" heat sheilds on my '72 and it turns out there aren't any (I think).
Old Dec 20, 2010 | 03:53 PM
Alan 71's Avatar
Alan 71
Hi,
I believe that by model year 70 just the upper shields were being used although the early (several thousand) 454 cars still had both upper and lower shields.
As far as I know the upper shields continued at least through model year 72.
The finish on them is a gray phosphate plating similar to the plating on the hood latches.
Regards,
Alan
Old Dec 20, 2010 | 03:58 PM
Alan 71's Avatar
Alan 71
Hi mb64,
I'd think that if your car ever had shields you see traces of the rivets or rivet holes that were used to install the lower bracket and/or the rivets or holes used to install the 2 upper stud plates.
I'm curious what you might find.
Regards,
Alan
Old Dec 20, 2010 | 06:55 PM
mudbone64's Avatar
mudbone64
Originally Posted by Alan 71
Hi mb64,
Regards,
Alan
As many times as I've been under my car I've never noticed any evidence of the lower heat shields. The firewall "splash" shields are in place and in very good condition and I don't remember them showing signs of any attaching hardware. Heck, I didn't even know there was a such thing as a lower heat shield until I saw them in the picture above. I guess since my car is a '72 I never noticed them in the AIM nor did I ever notice needing them after browsing through my many parts cataloges. If the temp in the dog-house (garage) gets above freezing perhaps I'll go out and take a look. If anything looks amiss I'll post it.
Thanks,
Gene
Old Dec 20, 2010 | 08:40 PM
7t3shark's Avatar
7t3shark
My '73 has the upper "splash shields". Wonder why they dropped the heat shield underneath? Bean counters maybe?
Old Dec 20, 2010 | 09:36 PM
mudbone64's Avatar
mudbone64
I don't know why the shields were dropped but it wouldn't be a bad mod. Anything to cool off the floor boards is a good thing.
Old Dec 20, 2010 | 09:49 PM
spinadog's Avatar
spinadog
Hi,
Regards,
Alan
Alan, I am curious on that note - my early (Feb) BB has no evidence of lower heat shields - any idea when that mod occurred? I'm fairly sure that it never had the lower ones but I plan on checking for any mounting points when I am under there this winter....
Old Dec 21, 2010 | 03:28 PM
fazang's Avatar
fazang
I have a question for FasterRat....
in this pic you have the foil looking sheilding....
I heard only the stock N14 cars would have that? Do you know if that is true ?
-ALF out..
Old Dec 21, 2010 | 05:10 PM
Faster Rat's Avatar
Faster Rat
ALF
The foil covered insulation you see is both under the floor boards and toe boards, as well as the transmission tunnel. It comes in three pieces and should have come from the factory on all '69s and other years as well. I haven't studied the other years so can't speak for sure which years. The metal floor pans and plastic toe boards only serve to protect the insulation from debris.
Original N14 cars had long pieces of foil covered insulation between the body and the top of the frame rail, which hung down an inch or so on the outside of the rail. Most of mine is still there, you just can't see it. One would have to lift the body off the frame in order to install, so it is somewhat difficult to fake...or in my case, replace.
Old Dec 21, 2010 | 05:18 PM
Alan 71's Avatar
Alan 71
Hi Gene,
I misunderstood.
I thought you said your car had no shields at all. I'd expect it to be as you've described....2 upper shields, but no sign of the 2 lower shields.
Regards,
Alan
Old Dec 21, 2010 | 05:25 PM
Alan 71's Avatar
Alan 71
Hi sad,
The info I'm looking at says just that it appears 'some early', 70 model,454 equipped, cars had the lower shields. It goes on to say 'several thousand' cars. I don't even know if that means the 454 cars that were among the first several thousand cars built, or the first several thousand 454 cars built.
More than a bit uncertain!?!
Regards,
Alan
Old Dec 21, 2010 | 06:09 PM
spinadog's Avatar
spinadog
Hi sad,
Regards,
Alan
Well, there were only about 4400 454 cars in 1970, so it probably meant the 454's of all the thousands of 'Vette's manufactured in early '70. Would be nice to see who has an original 454 from before Feb 19, 1970 to see if they have the shields.
Thanks for responding.
Simon.
To What are these hooks for???
