Diff crossmember bushings
Old Dec 23, 2010 | 09:51 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I used the aluminum pucks for 5-6 years I guess. During the frame off I had a look at them and noticed no wear marks whatsoever, meaning that the old, ugly, cracked bushings had never deflected sufficiently to allow any contact. I re-installed the crossmember with fresh paint and left the original bushings, warts and all. The pucks now make good drink coasters in the garage.
larger tires/wheels? more hp?
Old Dec 23, 2010 | 10:40 PM
Mike Ward's Avatar
Mike Ward
Much more HP, but I'm still trying to think of how the crossmember can be pulled away from the frame with enough force that it constacts the pucks.
Old Jan 9, 2011 | 07:14 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
being a "gotta find out for myself" kinda guy, I removed the bushings.
Metal around the rubber was in awful shape
Old Jan 9, 2011 | 09:40 PM
Ray Y's Avatar
Ray Y
Originally Posted by toddalin
These are the Guldstrand parts I use to locate the crossmember and the differential. They are still offered:
The two large aluminum disks locate the crossmember (above the rounded areas at the ends of the photo). The crossmember locates the differential. If there is slop, the differential can torque out of ideal alignment and induce wheel hop, etc.
The small aluminum disk replaces the front cushion and more securely mounts the differential, again to avoid twisting, wheel hop, etc.
Seems pretty straight forward to me (and Dick Guldstrand)
I recently got one of these kits from Tom's Differentials and I think they grabbed the wrong mix. I've got 2 of the smaller ones with a beveled area and only 1 large flat one. Please confirm I need 2 of the large ones.
Old Jan 9, 2011 | 10:16 PM
Mike Ward's Avatar
Mike Ward
So I guess you're going to change them now, huh?
Old Jan 9, 2011 | 10:59 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I removed the bushings, welded 1/8" steel plates to the bottom of the xmember and bolted it up...moved the diff up about 1/2"...not to mention the god awfull sounds transmitted through the frame/rollbar
Old Jan 10, 2011 | 10:54 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Nah, should slide right back in
You're right about the rubber though, it was still in decent shape
Old Jan 10, 2011 | 11:09 AM
Tom Sarno's Avatar
Tom Sarno
Did you weld the old cups from the bushings to the plate? Any pics?
Old Jan 10, 2011 | 10:46 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
It's been years but I don't think so. The holes in the center of the steel plate will keep it located. Sorry no pics.
Here's a little info on page 20-21 of this pdf...
http://www.corvettefaq.com/c3/vip.pdf
Old Feb 21, 2011 | 07:03 PM
airtime's Avatar
airtime
i wish i would have read this thread last week. i just removed my bushins and planned to replace them. they looked fine just wanted to start over fresh. the only place i have found them wanted 65 bucks a piece :o i am thinking about beating the old ones back in since they were in good shape. anyone removed the old ones and then reinstalled them?
what did you end up doing moonsteel?
Old Feb 21, 2011 | 07:26 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I installed new ones
Old Feb 21, 2011 | 08:37 PM
airtime's Avatar
airtime
where did you get them from?
