New Gas Tank!
Old Dec 29, 2010 | 10:41 AM
Apocolips's Avatar
Apocolips
Default New Gas Tank!
Well, I removed my gas tank yesterday. Found a small hole in the top edge where the strap was. Lots of rust inside as well and no sign of a build sheet. I ordered a new tank from Quanta.
For those that have done this, how many have painted/treated the outside of the new tank before installation? My car is always garaged and I don’t drive in the rain.
I also have a fuel filter question. My Qjet internal filter was removed do to the inlet threads being stripped beyond repair and then sealed. I have a filter between the pump and carb using rubber fuel hose. I don’t like the look and the close proximity of the filter and hot heads. Does it matter if the filter is installed between the tank and pump? I was thinking of putting the filter in the rear of the car with the tank.
Old Dec 29, 2010 | 11:13 AM
Duke94's Avatar
Duke94
The closer you can mount the filter to the carb the better since it would filter all the lines and the fuel pump as well. Other than that, there's no reason it can't be mounted on the frame rail like most modern FI cars/trucks. Note that there is a filter sock on the tank pickup that should be replaced during tank replacement.
Gary
Old Dec 29, 2010 | 12:33 PM
Apocolips's Avatar
Apocolips
Gary
I just pulled the sending unit out of the old tank and it was torn and open so it hasn't been doing any straining for a while. I have a new one on the way. Thanks!!
Old Dec 29, 2010 | 02:35 PM
Alan 71's Avatar
Alan 71
Hi apl,
Since the tank is in such a protected place I don't think it needs to be coated with anything, either inside or outside.
I'd just be careful installing the new anti-squeak cushions so the tank straps don't scratch the plating on the tank.
Good Luck!
Regards,
Alan
Old Dec 29, 2010 | 03:04 PM
DEEPSEA70's Avatar
DEEPSEA70
I just installed a new tank for the same reason. After cleaning the dirt of 40 years I too found small holes that eventually turned into bigger ones. The dirt and the straps must have kept the gas in. Anyway, I sprayed the new tank with a good coat of Rustoleum gavanized protector; mostly, looks like gray primer. I replaced the filter sock and gaskets. In leu of the paper tank straps; I had some old scuba tank straps(nylon webbing) that I used on the frame to support the tank for anti squeek. I also used them on the thinner tank straps. It should hold down on the friction and noise, and last for a very long time. I dont have a pic yet and the car is still on jack stands while I work on the trailing arms.
Hooyah Deepsea
Old Dec 30, 2010 | 10:56 AM
Apocolips's Avatar
Apocolips
I’m getting all of the necessary parts and stuff ready to install my new gas tank. When installing the new gasket between the filler neck and the tank, should I use some kind of gasket sealant or install it dry?
Old Dec 30, 2010 | 10:51 PM
Richard454's Avatar
Richard454
I don't know if this stuff is any good (saw it on Two Guys Garage)...
http://www.sharkhide.com/
Suppose to protect unfinished metals...
But if it does what they say -it's a little expensive at $60/quart- it's still cheaper than a new gas tank and could use it on other unfinished metals(alum as well) to protect them.
Richard
Old Dec 31, 2010 | 04:07 AM
groovyjay's Avatar
groovyjay
When I did the body off on my 79 I took the old tank out, soda blasted it and painted it with POR-15. After putting gas in it to see if there were any leaks I noticed that there were several. So I fabbed up a new aluminum tank...
Old Dec 31, 2010 | 10:09 AM
wan2run's Avatar
wan2run
I noticed a little rust around the middle seam of my tank when I pulled it out. I'm going to clean it up and use POR-15 Metal Mask before putting it back in.
Old Dec 31, 2010 | 10:32 AM
Apocolips's Avatar
Apocolips
Great info in all of the posts, but the question I still have is if I should use some kind of sealant along with the new filler neck gasket?
Old Jan 1, 2011 | 10:18 AM
Apocolips's Avatar
Apocolips
ttt
Old Jan 1, 2011 | 10:43 AM
bluthundr's Avatar
bluthundr
I just wiped mine down with mineral spirits and shot it with clear coat.
Old Jan 1, 2011 | 11:52 AM
V8 Interceptor's Avatar
V8 Interceptor
Last month, I changed the tank and I have not used sealant with the new filler neck gasket.
I painted the tank before installing.
So, will last for another forty years!
Old Jan 1, 2011 | 11:58 AM
Duke94's Avatar
Duke94
The AIM for my 78' shows NO sealer of any kind on the gasket.
Gary
Old Jan 1, 2011 | 03:52 PM
LancePearson's Avatar
LancePearson
Just out of curiosity...how do you remove the tank? drop your spare tire bucket and remove from the bottom and drop it assuming empty tank?
Old Jan 1, 2011 | 04:17 PM
V8 Interceptor
Under the tank there is a bracket bolted to the frame.
This is the procedure: empty tank, remove filler neck boot, remove the bracket, lower a few inches and disconnect the fuel lines on the tank.
After you put it down, pay attention to fuel lines.
It seems difficult, but it is very simple.
Sorry for my English.
Toti
Old Jan 1, 2011 | 05:27 PM
LancePearson
Thanks...I understand.
To New Gas Tank!
Old Jan 2, 2011 | 08:33 AM
Apocolips's Avatar
Apocolips
In my 1970 I had to drop the mufflers to get the tank out. A lot of manipulation and twisting. Wear safety glasses, alot of dirt and crud up and around the tank.
Old Jan 2, 2011 | 08:46 AM
LancePearson
I'm assuming if I have to do it I will take the spare tire bucket out, the mufflers off, clear it out to do it. Right now the exhaust is at the end of its useful life and I'm having a new one put on in early Feb. when I get back from a trip to Colorado. I may have the two #4 and #8 bushing's replaced at that time as well. The right hand ram's horn manifold has a crack in the casting and that will be either repaired via weld or more likely replaced so the major work will then be done on the car.
Old Jan 2, 2011 | 08:49 AM
LancePearson
the bushings I refer to are the body where it bolts to the frame, the back two, one on each side. Those two are rubber and look pretty much like cauliflower even though there are no sqeeks and movement. Should be easy enough to do. Also, four new shocks will go on as well. Don't know the existing one's provenance though the bolts are really solid with rust and the barrells of the shocks look pretty old. Rides well enough but I want to start fresh with knowing under my ownership when things were put on. New shocks in hand for installation.
