Steering Box Bolts, replace: Yes/No
Old Dec 31, 2010 | 11:43 AM
dburgjohn's Avatar
dburgjohn
Default Steering Box Bolts, replace: Yes/No
I pulled my steering box to have it rebuilt. Do I need to replace the three bolts and nuts that hold it to the frame?
Old Dec 31, 2010 | 02:51 PM
Alan 71's Avatar
Alan 71
Hi dbj,
If the bolts and nuts are in good condition, and haven't been compromised by lot's of rust deterioration, I'd say the originals can be reused.
Regards,
Alan
Happy New Year!
Old Dec 31, 2010 | 03:02 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Concur with Alan.
Clean them off really good with some solvent and check the bolt heads (under them) and the threads for shearing.
Old Dec 31, 2010 | 03:36 PM
dburgjohn's Avatar
dburgjohn
Default Look good
They do look good. Just knew there were some bolts that are recommened to be new. Thanks.
Old Jan 18, 2011 | 11:47 AM
dburgjohn's Avatar
dburgjohn
Default lock nuts?
I cleaned the bolt threads with a power wire brush and the nuts are still hard to turn, only going a few threads by hand. Are these self locking nuts used to bolt the box to the frame or do I need replacement nuts?
Old Jan 18, 2011 | 12:41 PM
Alan 71's Avatar
Alan 71
Hi dj,
I just took a look at my originals and the nuts seem to be ordinary fine threaded nuts. There is the usual split lock washer too which makes me think the nuts were nothing special.
I'd think you should be able to thread the nuts on the bolts with just normal fingers.
So?
Regards,
Alan
To Steering Box Bolts, replace: Yes/No
