Block for 383 build
Old Jan 3, 2011 | 09:54 PM
  #41
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://sdparts.com/details/gm-perfor...parts/88962516
These are brand new from GM and accept a factory type roller cam. If you don't want to spring for the Dart SHP this is a good option. GM says maximum bore 4.080.
Old Jan 3, 2011 | 10:05 PM
  #42
BLOCKMAN's Avatar
BLOCKMAN
We have used quite a few of those blocks over the years and the 10105123 was a good block till they started making them in Mexico same with the other 4 bolt main block.
And we had some of those new blocks that did not pass a sonic test and did send them back and they were replaced with no problem.
GM blocks still have to be checked even if they are new!!
Old Jan 3, 2011 | 10:15 PM
  #43
63mako's Avatar
63mako
This is the same part # as the Summit block for over $200 less. That should cover the cost of a sonic test and part of the shipping.
Old Jan 3, 2011 | 10:33 PM
  #44
timd02's Avatar
timd02
You would want to have it bored to .030 over wouldn't you? I know that it says that it is a finished bore of 4.000 but I haven't seen much in the way of rotating assemblies for that size bore.
Old Jan 3, 2011 | 10:43 PM
  #45
BLOCKMAN's Avatar
BLOCKMAN
plus it would have to be decked to zero or aleast square and deck and stroker clearanced.
The cam bearings should be removed while doing this work and GM line bores there cam bearings and sometimes when installing new ones the cam may not fit.
Now you have shipping, decking, boring and plate honing if you want a good job. remove cam bearings now how much do you tied up.
For a few more bucks you can buy a Dart SHP block all machined!!!
Old Jan 3, 2011 | 10:47 PM
  #46
eagle275's Avatar
eagle275
Default cranks..
Callies Compstar Crankshaft, Small Block Chevy 3.875 stroke, 350 mains, 2.100 rod journal
http://www.cnc-motorsports.com/produ...69&CtgID=26753
Callies Compstar Crankshaft, Small Block Chevy 4.000 stroke, 350 mains, 2.100 rod journal
http://www.cnc-motorsports.com/produ...71&CtgID=26753
Competition Rotating Assembly Kit, 3.875 Callies Crank, 6.000 Compstar Rods, JE 9.7:1 Pistons, Chevy 396 SBC
http://www.cnc-motorsports.com/produ...23&CtgID=28766
Old Jan 4, 2011 | 10:07 PM
  #47
timd02's Avatar
timd02
Here is the response I got back from Summit when I emailed them asking for more specifics on the 383 block they have for sale.
THESE ARE FULLY MACHINED 96-00 GM 350 4 BOLT MAI
CNC CLEARANCED FOR A 3.75" CRANK AND H-BEAM ROD
CAM BEARINGS INSTALLED AND LINE HONED FOR TRUE C
PIPE PLUGS INSTALLED
CNC BORED .030 OVER
TORQUE PLATE HONED
CNC DECKED SURFACE
CNC LINE HONED MAINS
BRASS FREEZE PLUGS INSTALLED
PROVISION FOR MECHANICAL FUEL PUMP HOLE
FINAL WASHED AND RUST PROTECTANT APPLIED
SUM-150122 DOWEL PIN KIT W/CAM PLUG Installed
PAINTED BLACK
The cylinder bore surface finish allows moly and chrome
rings, surface finish is 0.3 a 0.7 µm Ra ( 12 a 28µin Ra).
Block is decked to be flat and square -----
Minimum deck height would be 9.013"
Old Jan 4, 2011 | 10:28 PM
  #48
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would not bore a new block, there are not many pistons made for a 427ci small block but I found some from Mahle that were 4.125" which is standard bore size for 400ci block I would imagine it would be pretty easy to find 4.00" pistons for a 350ci block geese what is sense of boring a new block .030" over
Old Jan 5, 2011 | 08:25 AM
  #49
BLOCKMAN's Avatar
BLOCKMAN
CNC BORED .030 OVER
TORQUE PLATE HONED
CNC DECKED SURFACE
PAINTED BLACK
CNC line honed thats a new one, As I have never seen a CNC line hone set up.
Torque plate honed with what gasket and which hardware as we see it does make a differance between different gaskets and if you are using a studs or bolts.
You don't line hone cam bearings!!!!
Old Jan 5, 2011 | 11:05 AM
  #50
gkull's Avatar
gkull
I totally disagree Wayne When you buy these higher end $2000+ dollar blocks for building 427 - 472 ci what is another $100 to get the 4.155 bore and an additional 7 ci.
Lets just say that extra 7 ci gained you 10 hp. That is very cheap dollars per HP.
I have a 434 and I wished I had built a 447 ci for the same price. 4.155 X 4.125
Old Jan 5, 2011 | 06:19 PM
  #51
MotorHead's Avatar
MotorHead
I bet you wish your 427ci didn't blowed up 427ci just sounds cooler
Old Jan 6, 2011 | 09:01 AM
  #52
jackson's Avatar
jackson
$652 sum-150100
if the machinework is decent, then that's a good value for this (what the OP says is planned).
I'd suggest the GMPP 3.8" crank or similar 3.8" for this. FYI , the GMPP 383 also has specially clearanced rods unique to 383. For this, also suggest scat or eagle I-beam rods w/ the smaller capscrews. For this, typical H-beam is overkill, big, & needs more clearance than I-beam.
years back I built a 388" from an early 70s 2 pc rms 350 block. thirty overbore & scat 9000 cast 3.800" crank & self-clearanced old GM 5.7 rods, & get-em-anywhere pistons w/ 1.425" CH made 388" and created instant near-zero deck. Near-zero deck could also be accomplished w/ 3.8" w/ 6" rods & rather common 1.125" CH pistons.
Old Jan 6, 2011 | 09:08 AM
  #53
L88Plus's Avatar
L88Plus
Blocks with 880 cast into the sides are rumored to have shorter piston skirts than others - is there any truth to this, Blockman?
Old Jan 6, 2011 | 09:39 AM
  #54
jackson's Avatar
jackson
heck ... just under $3K buys a complete roller vortec motor from Year One and it makes about 400-415 hp.
here
http://forums.corvetteforum.com/1576432104-post7.html
Old Jan 6, 2011 | 09:45 PM
  #55
BLOCKMAN's Avatar
BLOCKMAN
The cylinders are shorter then the older blocks!!
Old Jan 7, 2011 | 08:04 AM
  #56
L88Plus's Avatar
L88Plus
^ That's what I mean to say, cylinders are shorter...piston skirts - where did I come up with that???
