heated 02 sensor for 82ce?
Old Jan 1, 2011 | 03:07 PM
1yy07's Avatar
1yy07
Default heated 02 sensor for 82ce?
the car runs fine. how would this help if anny? and how would you wire it
Old Jan 1, 2011 | 06:28 PM
Vette5.5's Avatar
Vette5.5
Why would you want to retro-fit a heated O2 sensor, if the car wasn't originally equipped with it. Only thing the heater does, is bring the sensor up to operating temperature sooner. Most newer car's have these, and usually the first thing to go bad. The government's also pushing pre-heated catalyst's for quicker light off too. Pretty sure your car run's open loop(no O2 sensor) until a certain coolant temperature anyway, so really no sense messing with thing's.
Old Jan 1, 2011 | 06:31 PM
hugie82's Avatar
hugie82
And a non heated sensor is cheaper...
Old Feb 4, 2011 | 08:18 PM
Sean82's Avatar
Sean82
the location of the sensor is a little too far back. the heated one will stay warmer. you have to remember that this is the first year of a feed back o2 sensor.
the fuel pump relay is behind the pass seat. it is powered with the engine running. I ran a power line from the battery to a bosh relay that was triggered by the fuel pump relay. I went to the wrecking yard and got a 3 wire o2 pig tail.
Old Feb 5, 2011 | 03:01 AM
7T1vette's Avatar
7T1vette
Heated O2 sensor in the '82 is unnecessary for reason stated above. It will serve no purpose other than costing more money and added rigging time.
Old Feb 5, 2011 | 03:09 AM
Shark Racer's Avatar
Shark Racer
They're helpful if you move the O2 sensor further downstream and it doesn't get hot enough to maintain closed loop.
Old Feb 5, 2011 | 10:45 AM
terry82's Avatar
terry82
if you go to a open exhaust ,sometimes you will get a check engine light .a heated o2 is the fix.
To heated 02 sensor for 82ce?
