350 vs 383
Old Jan 14, 2011 | 07:10 PM
Don Lind's Avatar
Don Lind
6th Gear
Default 350 vs 383
A few questions from a novice; I have 68 Corvette (number matching)327/350HP. With either a M20 or M21 transmission, rear-end I believe is a 3.36/1. I’m planning on removing the 327 (storing it) and replacing it with a 405hp/440TK.
1. I’m considering the purchase of either a 350 or 383 engine from Summit Racing or DPM Power. I was wondering if anyone has had any experience, good or bad, with either of these vendors and what it was.
2. Will the transmission handle the additional HP and torque or do I need to have it beefed up
3. Same question for the rear-end which I believe is a 3.36/1.
4. Assuming the HP and Torque are about the same, is there really that much difference between a 350 and a 383? If so what is it? I’ve read many comments saying to go with the 383 stroker, However, did not read an explanation ( maybe I missed it) of the reasoning behind it. I admit I’ve not read all the thread on engines
5. Is there another vendor I should look at? (I’ve ruled out CHS Machine Co. in Oregon based on negative comments in the forum)
Thanks for any advice you can give me
Oh yes I forgot one important question, will the 327 exhaust manifold bolt up to the 383 or will I need new manifolds to run to my side pipes ?
Rgards,
Don
Old Jan 14, 2011 | 07:17 PM
Scott Marzahl's Avatar
Scott Marzahl
Being in Maine, you should be talking to Carl (Blockman) for a killer 383 since he is in your backyard. Yes your trans is fine.
Old Jan 14, 2011 | 07:41 PM
carbster09's Avatar
carbster09
Generally speaking torque is a function of displacement. HP is a function of RPM. So, in very general terms with many other factors equal a 383 will give you an extra 30 ft lbs. Is this an important factor? Up to you .... but torque moves street engines.
Old Jan 14, 2011 | 10:03 PM
Don Lind's Avatar
Don Lind
6th Gear
Actualy I'm in Mass. about 20 miles west of Boston, next to Marlboro Mass.
Do you know of any one in this area I might speak with?
Thanks again.
Old Jan 14, 2011 | 10:06 PM
Imo Apita's Avatar
Imo Apita
Well as far as useless info is concerned, my 350 runs on 5 cylinders right now and my 383 will run on 8
No kidding my 383 will be bad-***.
Old Jan 14, 2011 | 10:42 PM
Manuel Azevedo's Avatar
Manuel Azevedo
The more cubic inchs at the same HP and rpm the smoother running the engine will be, (less cam lope)
Old Jan 14, 2011 | 10:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youll experience the torque increase at all rpms, youll love it.
It will leave in first better with your trans/rearend gearing and if you choose to lug the motor some it will do it much better than a 350.
For the street its real hard to beat a stroker youll love it.
It may only sound like 30 or so cubes wouldnt make a big difference but its the characteristic OF the power that youll like. I regret building a hot 350 this time around, even as overbuilt as it is a larger ci would feel a lot better.
Old Jan 15, 2011 | 08:05 AM
U17's Avatar
U17
Summit ZZ383... Great experience all around.... 425hp , 450# tq....
Old Jan 15, 2011 | 08:32 AM
L88Plus's Avatar
L88Plus
My son and I built comparable engines at the same time, each dropped into a late 90's Tahoe. He used RHS Vortec heads, I used GM's. I cleaned the bowls and short turns up on mine and just did bowl work on his, they didn't have GM's ridge. Same LT4 cam, same tune. His is a stroker, mine a 350. His truck is a 4-door, mine a 2-door, I'm guessing he outweighs me by 500lbs or so. His truck runs off and leaves mine like I'm tied to a post, the power difference is amazing. Part of it is probably due to the better heads, but that extra stroke/cubes makes more torque, period.
You really should find you a good rebuildable 400, the extra 1/8" of bore makes a bigger difference than you'd think when it comes to optimizing cylinder head breathing.
Old Jan 15, 2011 | 10:13 AM
DRIVESHAFT's Avatar
DRIVESHAFT
If the HP & Torque are the same then the 383 has no advantage.
But, if the HP & Torque are the same then there is something wrong with your 383.
Extra cubic inches are always a good thing when making power is the goal.
Old Jan 15, 2011 | 11:12 AM
Texana's Avatar
Texana
While I haven't purchased my 383 yet (wont have time to install for a few months anyways) I did call around several vendors, as I had questions relating to the engines. I have to say, I was very impressed with DMP at least on the service level. Its a smaller company, but they had the person responsible for building and testing the 383's call me back a few hours later. Its rare that you get to talk to someone who's not just looking at a fact sheet on the other end, and this guy really knew his stuff. I don't know what that's worth to you, but it left me feeling good about purchasing from them.
They were also are willing to do any customizing I'd like. They will use a chrome version of the intake for a little extra, or even paint the motor a color scheme of your choosing; you can even send them the paint you'd like them to use.
Belgian1979vette's Avatar
Belgian1979vette
Is the rear end ratio the same ?
Old Jan 15, 2011 | 11:40 AM
Scott Marzahl
Here are some actual chassis dyno numbers from a well tuned 327/350
293 ft-lb and 293 hp @ 5,500 so just think what a well built 383 will put down.
Old Jan 16, 2011 | 09:34 AM
69Zlover's Avatar
69Zlover
473tq @ 4500 and 443hp @ 5750 could have bumped it up a bit if I dropped the aluminum water pump and went to an electrical one but its about the looks Still pondering a turbo or pro charger but that might take away from its looks and advertise to much...
Old Jan 16, 2011 | 11:05 AM
L88Plus's Avatar
L88Plus
Yes, they are.
Old Jan 16, 2011 | 01:28 PM
Belgian1979vette
What I don't get is, if the only aspect that matters to an engine is ci, why not built a big block, like a 454 ?
Old Jan 16, 2011 | 03:29 PM
Scott Marzahl
Weight and handling are much better with a small block.
Old Jan 16, 2011 | 03:50 PM
Belgian1979vette
Sure, but i would assume that torque of a big block would be alot more and if weight would be an issue, you could use a aluminum block.
To 350 vs 383
